4 digit 7 Segment display with Arduino with Maxim7221
Humm one could use a 46” tv as a VGA monitor and forget all about this 7 segment stuff.
http://www.gammon.com.au/forum/?id=11608
Several answers/respoces seam to be lost. One question from OP and one answer from me.
@Larryd.
Maybe respect the question from OP? Yes, or no?
Too much of advice, especially extensions or major changes in the project... Does that help or confuse?
OP may not have considered or even knew this was an option.
Anyways, they can ignore the post, won’t hurt my feelings :cry:
@Larryd
I understand. However I remember my own topics, asking for help and I, sometimes, was flooded with suggestions. Those times it was too much. I had no power, no time, to evaluate "all other new suggestions".
Of cource, regarding the large amount of info being displayed, Your approach is really more handy.
Whandall:
What did the datasheets tell you?
Are you really expecting me to search for that information and/or test it in reality?
You can make a chain of 40 max7221 work on any Arduino,
it could be necessary to add some minor additional buffers/drivers.
You could buy 40 modules like these 10 modules.
and perform real tests.
The above is only an example, there are cheaper modules on aliexpress.
No I cannot used that one... because of two reasons.
  1. Max intergrated display not available in 1" size.
  2. I want to display 4 digit for each teacher....
img attached for better understanding.
Railroader:
As I see it, yes.
Start testing by using 2 MAX and LEDs and get hold of things. Then expand.
Once again, check what characters, and how, the MAX needs to be accessed.
Yes...
Thanks @wandall @railroader and @wawa and myself :wink:
I will move step by step.., also will make a single PCB for 2 line items (i.e. 2Teachers or 8 Digits) so I can easily extend and replace....
Again deep heart thanks all for your support... I will kickoff this sooon... and show u... Insha Allah
Whandall:
Bin-Matloob:
No I cannot used that one… because of two reasons.
  2. I want to display 4 digit for each teacher…
You are kidding, aren’t you?
For the test and the software development, the size and the orientation do not matter.
I understand that you should produce pcbs
with the correct sized leds and the correct orientation/spacing/you name it.
Even with the low priced pcbs I would try the concept first with bought pcbs,
the the wrong size and orientation does not matter for that purpose.
Whandall:
You are kidding, aren't you?
thats ok..... cool :slight_smile:
