Could anyone please suggest me a circuit diagram for connecting a 4-digit seven segment LED to a mcu. I would be using the gpio lines to control the led display. I am using LM5654-11 ledtech display for my application. The datasheet is Datasheet Loans – A guide to loans in the UK..
I am basically looking at what are the components that needs to be present in the circuit.
The datasheet says that is a common cathode display, and it quotes the LED voltage for 20mA forward current.
See attached schematic. I have only drawn one digit driver (the 470 ohm resistor + transistor) - you will need four of these. Similarly, I have only drawn one anode drive connection (the 150 ohm resistor) - you will need 7 of these, or 8 if you want to drive the decimal point as well (but use about 470 ohms for the decimal point instead of 150 ohms, otherwise it may be too bright).
This uses 11 Arduino output pins in total, or 12 if you include the decimal points. The 4 digit driver pins can be also used to multiplex push buttons or rotary encoders (using diode multiplexing) at the same time. If 11 pins is too many, there are ways of reducing the pin count using extra ICs.
As dhenry indicates, a MAX7219, $1.25 from taydaelectronics.com, will drive that part and use just 3 IO pins to do it. You wouldn’t even need multiplexing software, just need to update a value in a register when there was a change. Need one resistor to set max brightness level, and a 0.1uF cap from its Vcc pin to Gnd.
