4 Digit 7 Segment Tester
I wrote some simple code to test every segment of a 4 Digit 7 Segment LED Display. I know it is pretty basic, but I am proud of myself, and that is all that I care about. :slight_smile:
// About Me:
// This code was written by Jeremy Carlson
// Known as Jeremy1998 on Arduino Forums
// Email me at jeremyjcarlson@yahoo.com for help with code, hardware, or just to chat.
// About The Code:
// This code is written for use with displays connect with NPN Transistors.
// It can, however, easily be modified for use with direct drive of either common cathode or common annode displays.
// I will most likely be making updates for testing the colon and decimal.
// If I do, That will be posted on the Arduino Forums as well.
const byte digit[4] = {13, 12, 11, 10};         // Four digits on pins 13 - 10
const byte segment[7] = {9, 8, 7, 6, 5, 4, 3};  // Seven segments on pins 9 - 3
int time1 = 500;                                // A variable for storing the delays in void digits
int time2 = 100;                                // A variable for storing the delays in void segments
int repeatdigits = 5;                          // A variable for how many times void digits is called out
int repeatsegments = 5;                        // A variable for how many times voif segments is called out
int digitcount;                                 // A variable for storing what digit is on
int segmentcount;                               // A variable for storing what segment is on
int i;                                          // A variable for calling out void digit and void segment
 for (int i = 0; i < sizeof(digit) / sizeof(digit[0]); ++i) {      // Calculates all pins in the digit array
  pinMode (digit[i], OUTPUT);                                      // Declares them as outputs
 for (int i = 0; i < sizeof(segment) / sizeof(segment[0]); ++i) {  // Calculates all pins in the segment array
  pinMode (segment[i], OUTPUT);                                    // Declares them as outputs
void digits()
 for (i = 0; i < 4; i++) {                                          // Repeats the following four times
  digitcount + 1;                                                   // Adds one to the digitcount variable
  if(digitcount == 5){                                              // If digitcount is 5
   digitcount = 1;                                                  // Reset digitcount to 1
   digitalWrite(segment[i],HIGH);                                   // Turns them all on
  digitalWrite(digit[digitcount], HIGH);                            // Turns digit X on
  delay(time1);                                                     // Waits for X milleseconds
  digitalWrite(digit[digitcount], LOW);                             // Turns digit X on
   digitalWrite(segment[i],LOW);                                    // Turns them all off
void segments()
 for (i = 0; i < 7; i++) {                    // Repeats the following 7 times
  segmentcount + 1;                           // Adds one to segmentcount variable
  if(segmentcount == 8){                      // If segmentcount is 8
   digitcount + 1;                            // Reset digitcount to 1
   segmentcount = 1;                          // Reset segmentcount to 1
  digitalWrite(segment[segmentcount], HIGH);  // Turns segment X on
  delay(time2);                               // Waits for X milleseconds
  digitalWrite(digit[digitcount], LOW);       // Turns digit X off
  digitalWrite(segment[segmentcount], LOW);   // Turns segment X off
 for (i = 0; i < repeatdigits; i++) {    // Repeat the following X times
  digits();                              // Call out void digits
  digitcount = 0;                        // Reset digitcount to 0
 for (i = 0; i < repeatsegments; i++) {  // Repeat the following X times
  segments();                            // Call out void segments
  segmentcount = 0;                      // Reset segmentcount to 0
EDIT 1: I am noticing some errors in this code ( :-[). I am Currently fixing them and I will update the code as I find the fixes.
EDIT 2: It SHOULD be all fixed... Email me at the adress in the code, or leave a comment here if you notice any issues.
nice
Thanks!
digitcount + 1;
segmentcount + 1;
With warnings enabled (see http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1278712207)
you would have received "statement has no effect" on those, as the compiler doesn't know what to do with the result of the computation. Try
digitcount++;     // increment by one
digitcount+=10;  // increment by 10
When a coding construct is used many times, it is a good idea to encapsulate it:
#define COUNT(arr) (sizeof(arr) / sizeof(arr[0]))
#define foreach(var, arr) for (int var=0; var<COUNT(arr); ++var)
then, you could use e.g.
foreach (i, digit) {
   pinMode(digit[i], OUTPUT);
No love? :cry:
well, did you try my hints?
