Hi
Here I designed new module of seven segment and its programming code.
you can type degree or show Clock points.
the boards is disassembled , but it is easy to welding.
Suitable for making watches, thermometers, counters and ...
3-5 volt
46x8x21 mm
Red Color
seller link
Enjoy
sample code.pdf (245 KB)
SCH.PDF (53.8 KB)
ShiftDisplay Arduino Code.zip (425 KB)
Paul_B
October 15, 2019, 2:17pm
2
Do you know, that annoying module with the missing segment resistors and the dodgy multiplexing, is apparently no longer on eBay?
Just as well!
Current one is this one which is actually properly designed!
One 74HC595 per digit, no multiplexing and the correct resistors.
Hi
Already it is in Taobao,its chines market.
https://item.taobao.com/item.htm?spm=a312a.7700824.w4004-14847300825.18.16b05580xwucoH&id=605024172415
I tested it and no need to any resistors .
just take cpu for about ms.
Paul_B
October 15, 2019, 3:00pm
4
Shobeir:
As I said, really foolish design.
Paul__B:
I'm appreciate your checking , its about 0.5$ money talks ...
