Kind of new at this and I've run into a roadblock.
Anybody have any good ideas on how to check the status of 4 digital inputs and if 3 of them have gone high, then set a flag bit?
Basically i'm trying to check 4 reed switches, and if 3 of them have been tripped then set a bit that I can use to trigger the rest of my code in the loop. (I want 3 out of 4 for redundancy and fault tolerance.
I was thinking about checking the pins, and adding 1 to a bit if the result is true, and doing this for each input, then if the total is >3 then setting the flag, but that will just keep adding if only 1 switch is tripped.
This is what happens when I stay up till 5:30am playing C&C against co-workers..... that's so much easier than I was thinking.
Now comes the really stupid question, can I do the test directly on the inputs, or should I have the input states read into variables first, then do the math on the variables. That's how I think i have it below. I used an if loop cause i'm going to want out of the loop weather or not it's true.
#define reed1 8 // Reed switch 1
#define reed2 9 // Reed switch 2
#define reed3 10 // Reed switch 3
#define reed4 11 // Reed switch 4
int trip = 0; // Flag bit for tripped state
int sensor1 = 0;
int sensor2 = 0;
int sensor3 = 0;
int sensor4 = 0;
pinMode(reed1, INPUT);
pinMode(reed2, INPUT);
pinMode(reed3, INPUT);
pinMode(reed4, INPUT);
sensor1 = digitalRead(reed1); // Check for sensor trips
sensor2 = digitalRead(reed2); // Check for sensor trips
sensor3 = digitalRead(reed3); // Check for sensor trips
sensor4 = digitalRead(reed4): // Check for sensor trips
if((sensor1 + sensor2 + sensor3 + sensor4) > 3){
trip = 1;
Rest of my loop code here
