4 IR Sensors in Sumobot but not all are working
So we will have to make a sumobot for our project in Robotics. There are 4 IR sensors included but not all sensors is registered in the code. Attached is the code we have input.
This is also the link to the infrared sensors we are using: https://www.elecdesignworks.com/shop/prod0038/
//Ultrasonic sensor
#define trigPin 3
#define echoPin 2
//Motors
#define mL1 9 //left motor pin 1
#define mL2 8 //left motor pin 2
#define mR1 12 //right motor pin 1
#define mR2 13 //right motor pin 2
//IR sensors
int rearpinright = A5;
int rearpinleft = A4;
int frontpinright = A1;
int frontpinleft = A0;
Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(rearpinright, INPUT);
  pinMode(rearpinleft, INPUT);
  pinMode(frontpinright, INPUT);
  pinMode(frontpinleft, INPUT);
  pinMode(mL1, OUTPUT);
  pinMode(mL2, OUTPUT);
  pinMode(mR1, OUTPUT);
  pinMode(mR2, OUTPUT);
  digitalWrite(mL1, LOW);
  digitalWrite(mL2, LOW);
  digitalWrite(mR1, LOW);
  digitalWrite(mR2, LOW);
  delay(5500);
void leftF() { //left motor forwards
  digitalWrite(mL1, HIGH);
void leftR() { //left motor backwards
  digitalWrite(mL2, HIGH);
void rightF() { //right motor forwards
  digitalWrite(mR1, HIGH);
void rightR() { //right motor backwards
  digitalWrite(mR2, HIGH);
//Functions for motor control
void forwards() {
  leftF();
  rightR();
void backwards() {
  leftR();
  rightR();
void right() {
  leftF();
  rightR();
void left() {
  leftR();
  rightF();
void Stop() {
  long duration, distance;
  digitalWrite(trigPin, LOW);  // Added this line
  delayMicroseconds(2); // Added this line
  digitalWrite(trigPin, HIGH);
//  delayMicroseconds(1000); - Removed this line
  delayMicroseconds(10); // Added this line
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  Serial.print(distance);
 if (distance <= 10)
    forwards();
   else if (distance <=10)
    backwards();
    right();
if(frontLine_right()) {
    //Sensed white line in front
    backwards();
    delay(1000); //moves back for 1 second, change to a proper distance later
    left();
  else if(rearLine_right()) {
    //Sensed white line in back
    forwards();
    delay(1000); //moves forward for 1 second, change to a proper distance later
    left();
if(frontLine_left()) {
    backwards();
    right();
  else if(rearLine_left()) {
    forwards();
    right();
if(frontLine_right() and frontLine_right()) {
    backwards();
    left();
  else if(rearLine_right() and rearLine_left()) {
    forwards();
    left();
bool frontLine_right() { //checks if there is white below the front sensor
  int check = analogRead(frontpinright);
  Serial.println(check); //used to check data
  if(check > 600) { // if the voltage is above a certain value, we are on black. 100 was determined experimentally
    return false;
  else {
    return true;
bool frontLine_left() { //checks if there is white below the front sensor
  int check = analogRead(frontpinleft);
    return false;
  else {
    return true;
bool rearLine_right() { //checks if there is white below the front sensor
  int check = analogRead(rearpinright);
  //Serial.println(check); //used to check data
    return false;
  else {
    return true;
bool rearLine_left() { //checks if there is white below the front sensor
  int check = analogRead(rearpinleft);
    return false;
  else {
    return true;
Prototype.ino (5.92 KB)
Could you maybe post your code?
In code tags, obviously
Post a link to the IR sensors you are using and a schematic.
It appears from your code that the IR sensors are wired to give variable voltage.
you never call rearLine_right() or rearLine_left()
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
