4 LDRs + 2 DC MOTORS + 2 DROK L298N Motor Drive Board DC Dual H-Bridge
hi, i am having trouble with my dc motor turning directions.
my code works, it’s just when I cover up the left and right set of LDRs at two separate instances the motor still spins in the same direction.
it spins only clockwise and not counter clockwise. any ideas why?
i used code from this site to make the motor go forward and reverse:
and I modified user Spellmal’s code in the link below to incorporate the function of the 4 LDRs with respect to two motors
// connect motor controller pins to Arduino digital pins
// motor one, azimuth adjustment
int enA = 5;
int in1 = 6;
int in2 = 7;
// motor two, elevation adjustment
int enB = 8;
int in3 = 9;
int in4 = 10;
// LDR (Light Dependent Resistor) pin connections
// name = analog pin on respective arduino board;
//LDR top right
int topright = 0;
//LDR top left
int topleft = 1;
//LDR bottom left
int bottomleft = 2;
//LDR bottom right
int bottomright = 3;
//delay time in milliseconds
int dtime = 20;
//range of tolerance between LDR readings
int tolerance = 100;
//start millisecond count of LDR readings
int count = 0;
 // initialize the serial port:
 // set all the motor control pins to outputs
  pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
 int tr = analogRead(topleft);
 int tl = analogRead(topright);
 int bl = analogRead(bottomleft);
 int br = analogRead(bottomright);
//print resistance values to serial monitor for debugging
  Serial.println(tr);
  Serial.println(tl);
  Serial.println(bl);
  Serial.println(br);
//incremental count increase, continues to show LDR results
  count++;
  int avt= (tr + tl) / 2; // average value top
  int avd = (bl + br) / 2; // average value down
  int avl = (tl + bl) / 2; // average value left
  int avr = (tr + br) / 2; // average value right
  int avgTot = (tr+tl+bl+br)/4;
  int dvert = avt - avd; // check the difference of top and bottom LDRs
  int dhoriz = avl - avr;// check the difference of left and right LDRs
if (-1*tolerance > dvert || dvert > tolerance) // check if the difference is in the tolerance else change vertical angle
  if (avt > avd) //if average resistance on top is greater than on bottom
   digitalWrite(in3, HIGH);
   digitalWrite(in4, LOW);
   // set speed out of possible range 0~255
   analogWrite(enB, 10);
  else //avg resistance on bottom is greater than on top
   digitalWrite(in3, LOW);
   digitalWrite(in4, HIGH);
  else if (-1*tolerance < dvert || dvert < tolerance) //if difference is smaller than tolerance, stop vertical stepper
if (-1*tolerance > dhoriz || dhoriz > tolerance) // check if the difference is in the tolerance else change horizontal angle
  if (avl > avr)
   digitalWrite(in1, HIGH);
   digitalWrite(in2, LOW);
   // set speed to 200 out of possible range 0~255
   analogWrite(enA, 200);
   digitalWrite(in1, LOW);
   digitalWrite(in2, HIGH);
  else if (-1*tolerance < dhoriz || dhoriz < tolerance) //if difference in horizontal
  delay(dtime);
abs() is a very useful function/macro.
What, if anything, so the debug prints tell you about the robot’s behaviour?
In some of the cases you write to the enable pins whilst in others you don't. Is that correct ?
Can I suggest that you separate the code to set the motor speeds and and directions into functions with meaningful names so that the intention of your code is clearer.
For instance
       turnRight();
with a function like this
void turnRight()
If required you could pass the speed to the function as a parameter.
Using functions it will also be much easier to test them individually just by calling them.
hi, in all the cases I enable all pins simultaneously.
the solar tracker is suppose to move horizontally and vertically simultaneously.
i figured out what was the issue and the program works now. thanks.
it was the pulsewidth modulation pins in the arduino uno.
i had them numbered wrong.
now all of the pins for high/low are pwm pins.
just for some food for thought i did modify the code like you suggested.
i see how it will be useful for individually testing the program for motor direction and changing settings.
the code is written below. however, nothing moves now.
i am guessing it’s because the void function works only once.
i tried putting the void functions in the void loop function but i got errors.
should i move it elsewhere?
// pins on arduino uno for pwm (pulse width modulation) are 3,5,6,9,10,11
int enA = 7;
int in1 = 5;
int in2 = 6;
int enB = 8;
int in3 = 9;
int in4 = 10;
//LDR top right
int topright = 0;
//LDR top left
int topleft = 1;
//LDR bottom left
int bottomleft = 2;
//LDR bottom right
int dtime = 20;
int count = 0;
void turnclockwise()
  analogWrite(enA, 100);
void turncounterclockwise()
void horizontalstop()
void turnup()
void turndown()
void verticalstop()
  Serial.println(tr);
  Serial.println(tl);
  Serial.println(bl);
  Serial.println(br);
  count++;
  turnup();
  turndown();
  verticalstop();
  if (avl > avr)
  void turnclockwise();
  turncounterclockwise();
  horizontalstop();
  delay(dtime);
but i got errors
and I couldn't be arsed to post them.
abs() is really, really useful
i am guessing it's because the void function works only once.
Which function are you referring to ?
@groove :slight_smile:
sorry but i wasn’t sure how to implement the abs() function.
i figured since my code is working i didn’t want to risk messing it up.
would it work like this??.. i put it into my code and it compiles
//changed to
if (abs(tolerance) < dvert )
@ukhelibob
i wrote all these in the new revision of code and placed them right after void setup.
the code compiles, but doesn’t compile if i place them in the void loop.
basically for example when i place turnclockwise(); in my void loop the if statement it’s not cycling through and the motors don’t spin.
if (avl > avr)
turnclockwise();
void turnup()
void turndown()
void verticalstop()
int enA = 7;
int in1 = 5;
int in2 = 6;
int enB = 8;
int in3 = 9;
int in4 = 10;
//LDR top right
int topright = 0;
//LDR top left
int topleft = 1;
//LDR bottom left
int bottomleft = 2;
//LDR bottom right
int dtime = 20;
int count = 0;
void turnup()
void turndown()
void verticalstop()
  Serial.println(tr);
  Serial.println(tl);
  Serial.println(bl);
  Serial.println(br);
  count++;
if (abs(tolerance) < dvert) // check if the difference is in the tolerance else change vertical angle
  turnup();
  turndown();
  else if (abs(tolerance) > dvert) //if difference is smaller than tolerance, stop vertical stepper
  verticalstop();
if (abs(tolerance) < dhoriz) // check if the difference is in the tolerance else change horizontal angle
  if (avl > avr)
  turnclockwise();
  else if (abs(tolerance) > dhoriz) //if difference in horizontal
  horizontalstop();
  delay(dtime);
@groove
with regards to the abs() function
code that is working… not using abs() macro here…
int enA = 7;
int in1 = 5;
int in2 = 6;
int enB = 8;
int in3 = 9;
int in4 = 10;
//LDR top right
int topright = 0;
//LDR top left
int topleft = 1;
//LDR bottom left
int bottomleft = 2;
//LDR bottom right
int dtime = 20;
int count = 0;
  Serial.println(tr);
  Serial.println(tl);
  Serial.println(bl);
  Serial.println(br);
  count++;
  if (avl > avr)
  delay(dtime);
code that is not working…using abs() function/macro here
int enA = 7;
int in1 = 5;
int in2 = 6;
int enB = 8;
int in3 = 9;
int in4 = 10;
int topright = 0; //LDR top right
int topleft = 1; //LDR top left
int bottomleft = 2; //LDR bottom left
int bottomright = 3; //LDR bottom right
int dtime = 20;
int count = 0;
void turnup()
void turndown()
void verticalstop()
  Serial.println(tr);
  Serial.println(tl);
  Serial.println(bl);
  Serial.println(br);
  count++;
  turnup();
  turndown();
  verticalstop();
  if (avl > avr)
  turnclockwise();
  horizontalstop();
  delay(dtime);
Couldn’t find an instance of abs() in your code, but made an edit that may help with your concept of void loop() :wink:
#define returnNothing void
#define returnSmallUnsignedNumber byte
#define MediumSignedNumber int
int enA = 7;
int in1 = 5;
int in2 = 6;
int enB = 8;
int in3 = 9;
int in4 = 10;
//LDR top right
int topright = 0;
//LDR top left
int topleft = 1;
//LDR bottom left
int bottomleft = 2;
//LDR bottom right
int dtime = 20;
int count = 0;
returnNothing setup()
returnNothing loop()
  Serial.println(tr);
  Serial.println(tl);
  Serial.println(bl);
  Serial.println(br);
  count++;
  turnup();
  turndown();
  verticalstop();
  if (avl > avr)
 returnNothing turnclockwise();
  horizontalstop();
  delay(dtime);
returnNothing turncounterclockwise()
returnNothing horizontalstop()
returnNothing turnup()
returnNothing turndown()
returnNothing verticalstop()
ahh ic thanks...
i edited my last post and included the correct code with regards to the abs() function.
well i thought i would post my code that’s working if anyone wants to use it…
it should work for any sized dc motor as long as the proper power source and h bridge driver are used and of course the connections should be wired properly…
#define motormoves void
int enA = 3;
int in1 = 5;
int in2 = 6;
int enB = 9;
int in3 = 10;
int in4 = 11;
//LDR top right
int topright = 0;
//LDR top left
int topleft = 1;
//LDR bottom left
int bottomleft = 2;
//LDR bottom right
int dtime = 20;
int count = 0;
  Serial.println(tr);
  Serial.println(tl);
  Serial.println(bl);
  Serial.println(br);
  count++;
  turnup();  //vertical motor moves up
  turndown(); //vertical motor moves down
  verticalstop();
  if (avl > avr)
  turnclockwise(); //horizontal motor turns clockwise
  turncounterclockwise(); //horizontal motor turns counterclockwise
  horizontalstop();
  delay(dtime);
motormoves turnclockwise()
motormoves turncounterclockwise()
motormoves horizontalstop()
motormoves turnup()
  analogWrite(enB, 200);
motormoves turndown()
motormoves verticalstop()
