4 Led blinking using for statement
I recently started arduino but I have hard times solving basic problems. I attached problem below. I need code using for statement. Lend me a hand
post you code inside the code tags select </>
are you sure your wiring is correct?
not sure you have the wires from the bottom in the correct slots for the 2 LEDS on left and same for resistors
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu.
[code]Paste your sketch here[/code]
This is what the picture of the sketch says:
void setup ()  {
  for (int LEDi = 6; LEDi < 9; LEDi++) {
    pinMode (LEDi, OUTPUT) ;
void loop ()  {
  for (int LEDi = 6; LEDi <9; LEDi++)  {
    digitalWrite(LEDi,1) ;
    digitalWrite(LEDi,0) ;
The sketch compiles without error or warning so… what is the problem?
