4 load cell, 4amp, pcb
Hi, everyone here.
I am a student who is studying about road cell.
Read the data with the PCB combined with two load cells amp.(AMP PCB)
And esp32-c3-supermini, a PCB was made with a connector connected to the amplifier.(MPU PCB)
The test using two amp pcb and one mcu pcb.
However, there are cases where the value is not measured or not connected.
4 SCK and 4 DATA_OUT have been designated so that 4 load cells can be used. (I will upload the code, too.) I wonder if it is correct to use 4 amp or only 1 amp to know the data value of each load cell.
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN_1 = 1;
const int LOADCELL_SCK_PIN_1 = 0;
const int LOADCELL_DOUT_PIN_2 = 3;
const int LOADCELL_SCK_PIN_2 = 4;
const int LOADCELL_DOUT_PIN_3 = 6;
const int LOADCELL_SCK_PIN_3 = 5;
const int LOADCELL_DOUT_PIN_4 = 10;
const int LOADCELL_SCK_PIN_4 = 7;
HX711 scale1;
HX711 scale2;
HX711 scale3;
HX711 scale4;
  scale1.begin(LOADCELL_DOUT_PIN_1, LOADCELL_SCK_PIN_1);
  scale2.begin(LOADCELL_DOUT_PIN_2, LOADCELL_SCK_PIN_2);
  scale3.begin(LOADCELL_DOUT_PIN_3, LOADCELL_SCK_PIN_3);
  scale4.begin(LOADCELL_DOUT_PIN_4, LOADCELL_SCK_PIN_4);
 GetScale(scale1,1);
 GetScale(scale2,2);
 GetScale(scale3,3);
 GetScale(scale3,4);
void GetScale(HX711 scale, byte No ){
  if (scale.is_ready()) {
    long reading = scale.read();
    Serial.print("HX711 No. ");
    Serial.print(No);
    Serial.print(" reading: ");
    Serial.println(reading);
    Serial.print(No);
    Serial.println(" not found.");
One should be scale3, the other should be scale4. Plz correct it.
If the load cells belong to one scale then all four can be combined into a single bridge. AFAIR there exists a PCB for that purpose.
Oh thank, I forgot to fix it
So you have to write four amps to get four different load cell values...
