4 relay controller with schedule and manual switch button
Hello, i have a project with relays that can switch manually using switch button and can also switch automatically with schedule, i already have a DS1302 and its working with relay but my problem is when i combine the code for relay using switch button and the schedule using DS1302, and the DHT11 for sensor > 20 will turn on relay, there is a delay and sometimes the buttons are not working.
this is my current code
#include <virtuabotixRTC.h>
#include <DHT.h>
#define DHTPIN 13 //Connect Out pin to D2 in NODE MCU
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// constants won't change
const int BUTTON_PIN = 12; // Arduino pin connected to button's pin
const int BUTTON_PIN3 = 11; // Arduino pin connected to button's pin
const int BUTTON_PIN2 = 10; // Arduino pin connected to button's pin
const int BUTTON_PIN1 = 9; // Arduino pin connected to button's pin
const int RELAY_PIN = 4; // Arduino pin connected to relay's pin
const int RELAY_PIN3 = 2; // Arduino pin connected to relay's pin
const int RELAY_PIN2 = 3; // Arduino pin connected to relay's pin
const int RELAY_PIN1 = 5; // Arduino pin connected to relay's pin
virtuabotixRTC myRTC(6, 7, 8);
const int OnHour = 10; //SET TIME TO ON RELAY (24 HOUR FORMAT)
const int OnMin = 45;
const int OffHour = 10; //SET TIME TO OFF RELAY
const int OffMin = 47;
// variables will change:
int relayState = LOW; // the current state of relay
int lastButtonState; // the previous state of button
int currentButtonState; // the current state of button
int relayState1 = LOW; // the current state of relay
int lastButtonState1; // the previous state of button
int currentButtonState1; // the current state of button
int relayState2 = LOW; // the current state of relay
int lastButtonState2; // the previous state of button
int currentButtonState2; // the current state of button
int relayState3 = LOW; // the current state of relay
int lastButtonState3; // the previous state of button
int currentButtonState3; // the current state of button
pinMode(BUTTON_PIN, INPUT_PULLUP); // set arduino pin to input pull-up mode
pinMode(RELAY_PIN, OUTPUT); // set arduino pin to output mode
pinMode(BUTTON_PIN1, INPUT_PULLUP); // set arduino pin to input pull-up mode
pinMode(RELAY_PIN1, OUTPUT); // set arduino pin to output mode
pinMode(BUTTON_PIN2, INPUT_PULLUP); // set arduino pin to input pull-up mode
pinMode(RELAY_PIN2, OUTPUT); // set arduino pin to output mode
pinMode(BUTTON_PIN3, INPUT_PULLUP); // set arduino pin to input pull-up mode
pinMode(RELAY_PIN3, OUTPUT); // set arduino pin to output mode
digitalWrite(RELAY_PIN,LOW);
digitalWrite(RELAY_PIN1,LOW);
digitalWrite(RELAY_PIN2,LOW);
digitalWrite(RELAY_PIN3,LOW);
currentButtonState = digitalRead(BUTTON_PIN);
currentButtonState1 = digitalRead(BUTTON_PIN1);
currentButtonState2 = digitalRead(BUTTON_PIN2);
currentButtonState3 = digitalRead(BUTTON_PIN3);
// Set the current date, and time in the following format:
// seconds, minutes, hours, day of the week, day of the month, month, year
myRTC.setDS1302Time(00, 44, 10, 3, 30, 11, 2022);
dht.begin();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(F(" Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.print(F("C "));
Serial.print(f);
Serial.print(F("F Heat index: "));
Serial.print(hic);
Serial.print(hif);
Serial.println(F("F"));
// This allows for the update of variables for time or accessing the individual elements.
myRTC.updateTime();
int buttonState = digitalRead(BUTTON_PIN); // read new
int buttonState1 = digitalRead(BUTTON_PIN1); // read new state
int buttonState2 = digitalRead(BUTTON_PIN2); // read new state
int buttonState3 = digitalRead(BUTTON_PIN3); // read new state
// Start printing elements as individuals
Serial.print("Current Date / Time: ");
Serial.print(myRTC.dayofmonth);
Serial.print("/");
Serial.print(myRTC.month);
Serial.print("/");
Serial.print(myRTC.year);
Serial.print(" ");
Serial.print(myRTC.hours);
Serial.print(":");
Serial.print(myRTC.minutes);
Serial.print(":");
Serial.println(myRTC.seconds);
// Delay so the program doesn't print non-stop
lastButtonState = currentButtonState; // save the last state
lastButtonState1 = currentButtonState1; // save the last state
lastButtonState2 = currentButtonState2; // save the last state
lastButtonState3 = currentButtonState3; // save the last state
currentButtonState = digitalRead(BUTTON_PIN); // read new state
currentButtonState1 = digitalRead(BUTTON_PIN1); // read new state
currentButtonState2 = digitalRead(BUTTON_PIN2); // read new state
currentButtonState3 = digitalRead(BUTTON_PIN3); // read new state
if (t > 20){ digitalWrite(RELAY_PIN2, LOW);}
if(lastButtonState == LOW && currentButtonState == HIGH) {
Serial.println("The button is pressed");
// toggle state of relay
relayState = !relayState;
// control relay arccoding to the toggled state
digitalWrite(RELAY_PIN, relayState);
if(lastButtonState1 == HIGH && currentButtonState1 == LOW) {
Serial.println("Relay 1");
relayState1 = !relayState1;
digitalWrite(RELAY_PIN1, relayState1);
if(lastButtonState2 == HIGH && currentButtonState2 == LOW) {
Serial.println("Relay 2");
relayState2 = !relayState2;
digitalWrite(RELAY_PIN2, relayState2);
if(lastButtonState3 == HIGH && currentButtonState3 == LOW) {
Serial.println("Relay 3");
relayState3 = !relayState3;
digitalWrite(RELAY_PIN3, relayState3);
// control using schedule
if(myRTC.hours == OnHour && myRTC.minutes == OnMin){
digitalWrite(RELAY_PIN, LOW);
Serial.println("LIGHT ON");
else if(myRTC.hours == OffHour && myRTC.minutes == OffMin){
digitalWrite(RELAY_PIN,HIGH);
Serial.println("LIGHT OFF");
Schematics are valuable as relays do need special care.
Please post code, not text like this. Read 'how to' here: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
A wild guess... Does any device use SPI? You use some I/O for buttons that are also used for SPI.
Sorry i cant upload , because I'm a new user
But You can download the linked info, follow it and post code according to the advice.
Hello markii_2430
Welcome to the forum.
This is a free forum service to get you started.
#include <DHT.h>
  digitalWrite(RELAY_PIN1, LOW);
  digitalWrite(RELAY_PIN3, LOW);
  dht.begin();
    return;
  Serial.print(h);
  Serial.print(t);
  Serial.print(f);
  Serial.print(hic);
  Serial.print(hif);
  myRTC.updateTime();
  Serial.print("/");
  Serial.print("/");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
  if (t > 20) {
  if (lastButtonState == LOW && currentButtonState == HIGH) {
  if (lastButtonState1 == HIGH && currentButtonState1 == LOW) {
  if (lastButtonState2 == HIGH && currentButtonState2 == LOW) {
  if (lastButtonState3 == HIGH && currentButtonState3 == LOW) {
  if (myRTC.hours == OnHour && myRTC.minutes == OnMin) {
  else if (myRTC.hours == OffHour && myRTC.minutes == OffMin) {
    digitalWrite(RELAY_PIN, HIGH);
Enjoy the day and have fun.
