4 relay homemade pcb
hellow, i want to create a 4 realy pcd with 3 pins screw terminals. i want to have a separate power supply from arduino, and maybe i will also put some leds on it. Even thow i have done this in my breadboard, i dont know how to start to make a pcb with this and how is the best way to put them in a pcb. Are any already done desings for this thing?
thanks in advance
Try searching Google for 'Arduino relay shield'. I found this one and there are probably a lot more. http://www.robotshop.com/seeedstudio-arduino-relay-shield.html?utm_source=google&utm_medium=base&utm_campaign=jos
Don
If you can't find one that does what you want, then you can create a schematic and breadboard using software such as www.expresspcb.com or eagle from www.cadsoft.de/info.htm
thanks.
I just want to try make it myself…
I think you will learn some new stuff by doing it yourself. Look at the examples given above ..
Take a look at this one, which also has the schematic diagram: http://arduino-direct.com/sunshop/index.php?l=product_detail&p=155
You might decide to use optical isolation like in this one: http://arduino-direct.com/sunshop/index.php?l=product_detail&p=156
Get some prototype / perforated board and built the first one that way. Later design a PCB if you want. Get your design working first..
More about relays and power here: http://arduino-info.wikispaces.com/ArduinoPower
PM me if you want just the relays themselves, pretty cheap... I am thinking of stocking some..
hi,
You managed to accomplish diagram, wiring and installation practice?
I redesigned schematic from http://arduino-direct.com/sunshop/index.php?l=product_detail&p=155 using EAGLE software: - schematic: http://i47.tinypic.com/9jowhx.png - board: http://i49.tinypic.com/152i0du.png - board with components: http://i50.tinypic.com/30krb69.gif - a 3D view: http://i47.tinypic.com/2copz7n.jpg
best regard, niq_ro
Hi, Nice example of the process of designing a board...
