I've got a 4 module relay board. all the tutorials on the internet tell you to remove the jumper between the VCC and JD-VCC pins and then connect VCC and GRD to a 2nd power supply to maintain isolation. The problem i have is I've not got a second GRD only to one that connects to the arduino. The link below shows a picture of my relay board but still doesn't explain how to connect the 2nd power supply for the relays.
I think that the Arduino should only connect to the Vcc and INx pins. No connection from Arduino to the relay module GND pin. Remove the JD-Vcc jumper and connect the external supply to the JD-Vcc pin and the GND pin.
Thanks Ground fungus, i thought that might be the case but i wanted to make sure before i connected it up and blew something. I've connected a 5V DC power supply across the GRD and JD-VCC pins and still the relay's don't click on and off. I've also tested the output pins and i get the same continuity on a powered relay as i do un-powered. I know the relays are being triggered by the arduino as the LED's come on. Do i need more than 5V DC to power the relay coils perhaps?
I assumed they are 5v as all the info on the internet says to connect a 5vDC supply to power the relays. They will be switching a 24V DC circuit but that's something separate. Yes the arduino VCC is connected to the relay board VCC and the arduino outputs connect to the IN1-3. The leds on the relay board come on and off as the arduino code runs so i know that bits working fine. I've tested the relay contacts NO/NC and common with a multimeter and i get the same results wheather the LED for that relay is on or off. I just cant get the relay coils to operate to close the relays contacts.
I'll upload a photo in a bit when i find my camera lead. The info on the top of the relays all relates to the switching contacts capacity i think. It says 12VDC, 10A 250VAC, 15A 125VAC, 10A 250VAC, JQC-3FF-S-Z. I brought this one as it can switch both 250VAC and 12VDC curcuits, as i need to control a 12VDC and 240VAC pump and valve with it.
jamesb123:
I brought this one as it can switch both 250VAC and 12VDC circuits, as i need to control a 12VDC and 240VAC pump and valve with it.
Almost all of these relays are rated to switch either AC or DC so that is not a matter of choice but you will note that the rated DC voltage is below 30 V as above that voltage a DC supply may maintain an arc as the contacts open and damage or destroy the relay.
