Hello, good morning, im using 4 servos(360°) controles with an ir remite control, could i make a command run and tell it another and stop the previous one ?(for example, go forward all the time until it tells you to go to the right then stop executing the command forward and start the command right and let it do that with everyone), because now it executes a command for a certain period of time and it doesn't matter if I say another one because it doesn't stop.
The code:
#include <Servo.h>
#include <IRremote.h>
#define FORWARD 0x8D0
#define BACKWARD 0x4D0
#define LEFT 0x2F0
#define RIGHT 0xAF0
#define STOP 0xA90
Servo servo_FL;
Servo servo_FR;
Servo servo_BL;
Servo servo_BR;
int pinIr=12;
IRrecv receiver(pinIr);
decode_results results;
servo_FL.attach(2);
servo_FR.attach(3);
servo_BL.attach(4);
servo_BR.attach(5);
receiver.enableIRIn();
if(receiver.decode(&results)){
switch(results.value){
case FORWARD:
servo_FL.write(0);
servo_FR.write(180);
servo_BL.write(0);
servo_BR.write(180);
case BACKWARD:
servo_FL.write(180);
servo_FR.write(0);
servo_BL.write(180);
servo_BR.write(0);
case RIGHT:
servo_FL.write(0);
servo_FR.write(87);
servo_BL.write(0);
servo_BR.write(88);
case LEFT:
servo_FL.write(81);
servo_BL.write(72);
case STOP:
servo_FL.write(81);
servo_FR.write(87);
servo_BL.write(72);
servo_BR.write(88);
receiver.resume();
else{ //stop
servo_FL.write(81);
servo_FR.write(87);
servo_BL.write(72);
servo_BR.write(88);
delay(40);
