:o
Hi there,
I'm having difficulty with a project where I'm running 4 NEMA 17 motors on a CNC shield attached to an Arduino Uno operated by a wifi module. I had the wifi module attached but sadly it won't work in the timeframe I'm hoping to finish this project (a week) so I'm using an IR sensor with a remote instead.
Basically my question is, I've separated the 4 motors by finding their dir/step numbers but I can't figure out how to code them in a sequence where they are moving at different speeds and times. Can anyone help?
Below is my code so far;
For the motors:
// Define stepper motor connections and steps per revolution:
#define dirPinX 5
#define stepPinX 2
#define dirPinY 6
#define stepPinY 3
#define dirPinZ 7
#define stepPinZ 4
#define dirPinA 13
#define stepPinA 12
#define enablePin 8
#define stepsPerRevolution 200
// Declare pins as output:
pinMode(stepPinX, OUTPUT);
pinMode(dirPinX, OUTPUT);
pinMode(stepPinY, OUTPUT);
pinMode(dirPinY, OUTPUT);
pinMode(stepPinZ, OUTPUT);
pinMode(dirPinZ, OUTPUT);
pinMode(stepPinA, OUTPUT);
pinMode(dirPinA, OUTPUT);
pinMode(enablePin, OUTPUT);
// Set the spinning direction clockwise:
digitalWrite(dirPinX, HIGH);
digitalWrite(dirPinY, HIGH);
digitalWrite(dirPinZ, HIGH);
digitalWrite(dirPinA, HIGH);
digitalWrite(enablePin, LOW);
// Spin the stepper motor 1 revolution slowly:
for (int i = 0; i < stepsPerRevolution; i++) {
// These four lines result in 1 step:
digitalWrite(stepPinX, HIGH);
digitalWrite(stepPinY, HIGH);
digitalWrite(stepPinZ, HIGH);
digitalWrite(stepPinA, HIGH);
delayMicroseconds(2000);
digitalWrite(stepPinX, LOW);
digitalWrite(stepPinY, LOW);
digitalWrite(stepPinZ, LOW);
digitalWrite(stepPinA, LOW);
// Set the spinning direction counterclockwise:
digitalWrite(dirPinX, LOW);
digitalWrite(dirPinY, LOW);
digitalWrite(dirPinZ, LOW);
digitalWrite(dirPinA, LOW);
// Spin the stepper motor 1 revolution quickly:
delayMicroseconds(1000);
// Spin the stepper motor 5 revolutions fast:
for (int i = 0; i < 5 * stepsPerRevolution; i++) {
delayMicroseconds(500);
//Spin the stepper motor 5 revolutions fast:
Any help would be greatly appreciated!!<3 Thanks in advance
