4 stepper motors
At the beginning i want to apologize for my English.
This is going to be my first arduino project and I have some questions. I want to operate on 4 stepper motors (e.g.). Is it possible to use two of these on a Arduino Uno Rev3 / Arduino Leonardo.
On the Internet I found that 4 EasyDriver Stepper Motor Driver could work, which option is better?
Next question, if it is possible,will be there some "slots" left so I be able to connect light sensor and one servo (servomechanism).
Motors wont be used at the same time, so I dont think power will be an issue (correct me if I'm wrong :wink: )
The main concept is that, every single motor will do his part (e.g. motor 1 half step then motor 2 full step and so on) then servo will move if light sensor detects light.
Greetings
Yes.
Not sure what you mean by slots but yes you can control them at the same time.
No idea because you haven't said how you will power them.
p-hello:
I would choose the EasyDrivers as they give you a lot more flexibility at the expense of a little more installation complexity. Also, if you accidentally damage one of them ...
You might want to look at this interesting advice about a suitable power supply. Obviously you will need to adjust the values from the BigEasydriver to your smaller Easydriver.
...R
