4 Wheel Obstacle Avoiding Car
Hello!
I've been working on this project for months, and finally i finished the hardware part of it, but now i got big troubles with the code.
I've tried to search and copy, even edit some of them but still i can't make it work.
The Car has a Motor Shield, attached to Arduino Uno.
On the Motor Shield i have connected:
4 Wheels
1 Servo Motor (SERVO 1 on the shield, pin 10 arduino)
Ultrasonic Sensor attached to the Servo (A0 Trig, A1 Echo)
and ofcourse 5v and gnd for the ultrasonic.
the circuit is being powered by 3 18650 batteries with output total of ~9-12V
There's a 330μF Capacitor on the Servo.
Could someone tell me a simple code for it?
Just like that:
move forward until you see an obstacle.
When you see it, check left and right and go if there are no obstacles.
I Have tried many of other project's code, but either my car doesn't stop to obstacles, or it stops randomly without any obstacle.
PS: I have checked for the ultrasonic connection with Serial Monitor, and it works perfectly.
Any help would be really appreciated!
Thanks!
The Attachment:
What motor shield? What motors? What servo? What sensor? How is the vehicle steered? Links please. Details are important.
Post the code you have that comes nearest to working and tell us what it does right and what it doesn't do. Then we can probably help you get it working. But if you have designed hardware that is different from other projects then the code needed to run it is not likely to be exactly like anyone else's code.
Steve
Motor Shield: Arduino Playground - AdafruitMotorShield
Sensor: HC-SR04
Servo: Tower Pro Micro Servo 9g (SG90)
This Code is working but:
It randomly stops and reads distance
When it has to turn left, it sometimes turn right instead
When turning left or right, does it with really high speed and doing almost a 300° turn.
#include <AFMotor.h>      //add Adafruit Motor Shield library
#include <Servo.h>        //add Servo Motor library
#include <NewPing.h>      //add Ultrasonic sensor library
#define TRIG_PIN A0 // Pin A0 on the Motor Drive Shield soldered to the ultrasonic sensor
#define ECHO_PIN A1 // Pin A1 on the Motor Drive Shield soldered to the ultrasonic sensor
#define MAX_DISTANCE 300 // sets maximum useable sensor measuring distance to 300cm
#define MAX_SPEED 70 // sets speed of DC traction motors to 150/250 or about 70% of full speed - to get power drain down.
#define MAX_SPEED_OFFSET 40 // this sets offset to allow for differences between the two DC traction motors
#define COLL_DIST 30 // sets distance at which robot stops and reverses to 30cm
#define TURN_DIST COLL_DIST+20 // sets distance at which robot veers away from object
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE); // sets up sensor library to use the correct pins to measure distance.
AF_DCMotor leftMotor1(1, MOTOR12_1KHZ); // create motor #1 using M1 output on Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor leftMotor2(2, MOTOR12_1KHZ); // create motor #2, using M2 output, set to 1kHz PWM frequency
AF_DCMotor rightMotor1(3, MOTOR34_1KHZ);// create motor #3, using M3 output, set to 1kHz PWM frequency
AF_DCMotor rightMotor2(4, MOTOR34_1KHZ);// create motor #4, using M4 output, set to 1kHz PWM frequency
Servo myservo;  // create servo object to control a servo
int leftDistance, rightDistance; //distances on either side
int curDist = 0;
String motorSet = "";
int speedSet = 0;
//-------------------------------------------- SETUP LOOP ----------------------------------------------------------------------------
  myservo.attach(10);  // attaches the servo on pin 10 (SERVO_1 on the Motor Drive Shield to the servo object
  myservo.write(65); // tells the servo to position at 90-degrees ie. facing forward.
  delay(1000); // delay for one seconds
//---------------------------------------------MAIN LOOP ------------------------------------------------------------------------------
  myservo.write(65);  // move eyes forward
  delay(90);
  curDist = readPing();   // read distance
  if (curDist < COLL_DIST) {changePath();}  // if forward is blocked change direction
  moveForward();  // move forward
void changePath() {
  moveStop();   // stop forward movement
  myservo.write(7);  // check distance to the right
    rightDistance = readPing(); //set right distance
    myservo.write(144);  // check distace to the left
    delay(700);
    leftDistance = readPing(); //set left distance
    myservo.write(65); //return to center
    delay(100);
    compareDistance();
void compareDistance()   // find the longest distance
  if (leftDistance>rightDistance) //if left is less obstructed
    turnLeft();
  else if (rightDistance>leftDistance) //if right is less obstructed
    turnRight();
   else //if they are equally obstructed
    turnAround();
int readPing() { // read the ultrasonic sensor distance
  delay(70);
  unsigned int uS = sonar.ping();
  int cm = uS/US_ROUNDTRIP_CM;
  return cm;
void moveStop() {leftMotor1.run(RELEASE); leftMotor2.run(RELEASE); rightMotor1.run(RELEASE); rightMotor2.run(RELEASE);}  // stop the motors.
void moveForward() {
    motorSet = "FORWARD";
    leftMotor1.run(FORWARD);      // turn it on going forward
    leftMotor2.run(FORWARD);      // turn it on going forward
    rightMotor1.run(FORWARD);     // turn it on going forward
    rightMotor2.run(FORWARD);     // turn it on going forward
  for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
    leftMotor1.setSpeed(speedSet);
    leftMotor2.setSpeed(speedSet);
    rightMotor1.setSpeed(speedSet);
    rightMotor2.setSpeed(speedSet);
    delay(5);
void moveBackward() {
    motorSet = "BACKWARD";
    leftMotor1.run(BACKWARD);     // turn it on going backward
    leftMotor2.run(BACKWARD);     // turn it on going backward
    rightMotor1.run(BACKWARD);    // turn it on going backward
    rightMotor2.run(BACKWARD);    // turn it on going backward
    delay(5);
void turnRight() {
  motorSet = "RIGHT";
  leftMotor1.run(FORWARD);      // turn motor 1 forward
  leftMotor2.run(FORWARD);      // turn motor 2 forward
  rightMotor1.run(BACKWARD);    // turn motor 3 backward
  rightMotor2.run(BACKWARD);    // turn motor 4 backward
  rightMotor1.setSpeed(speedSet+MAX_SPEED_OFFSET);
  rightMotor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
  delay(1500); // run motors this way for 1500
  leftMotor1.run(FORWARD);      // set both motors back to forward
void turnLeft() {
  motorSet = "LEFT";
  leftMotor1.run(BACKWARD);      // turn motor 1 backward
  leftMotor2.run(BACKWARD);      // turn motor 2 backward
  leftMotor1.setSpeed(speedSet+MAX_SPEED_OFFSET);
  leftMotor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
  rightMotor1.run(FORWARD);     // turn motor 3 forward
  rightMotor2.run(FORWARD);     // turn motor 4 forward
void turnAround() {
  motorSet = "RIGHT";
  delay(1700); // run motors this way for 1700
