4021 Shift In Codes to light up LEDs ! SHARING !
hello guys,
i managed to make a program, using the codes from the tutorial here on the website of the IC 4021 Shift In, that lights some LEDs when a certain push button is pressed so i thought about sharing it if anyone is in need
(for the circuit use the same one in this tutorial https://www.arduino.cc/en/Tutorial/ShiftIn )
so here it is :
(Note: If you have a better way please post it i would be glad to go by it :slight_smile: )
//4021 Shift In controlling LEDs
//define where your pins are
int latchPin = 8;
int dataPin = 9;
int clockPin = 7;
//Define variables to hold the data
//for shift register.
//starting with a non-zero numbers can help
//troubleshoot
byte switchVar1 = 72;  //01001000
//define an array that corresponds to values for each
//of the shift register's pins
boolean lastPushButton1 = LOW;
boolean currentPushButton1 = LOW;
boolean lastPushButton2 = LOW;
boolean currentPushButton2 = LOW;
boolean lastPushButton3 = LOW;
boolean currentPushButton3 = LOW;
boolean lastPushButton4 = LOW;
boolean currentPushButton4 = LOW;
  //start serial
  //define pin modes
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, INPUT);
  //the arduino Pins that the LEDs are connected to
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
    //Pulse the latch pin:
    //set it to 1 or HIGH to collect parallel data
    digitalWrite(latchPin,1);
    //wait
    delayMicroseconds(0.5);
    //set it to 0 or LOW to transmit data serially
    digitalWrite(latchPin,0);
    //while the shift register is in serial mode
    //collect each shift register into a byte
    //the register attached to the chip comes in first
    switchVar1 = shiftIn(dataPin, clockPin);
    //Switch Statement to check which push button is pressed to light up the RIGHT LED !
    switch (switchVar1) {
      case B00000001:
        currentPushButton1 = !currentPushButton1;
        if(lastPushButton1 != currentPushButton1 == HIGH){
          digitalWrite(2, currentPushButton1);
        lastPushButton1 = currentPushButton1;
      case B00000010:
        currentPushButton2 = !currentPushButton2;
        if(lastPushButton2 != currentPushButton2 == HIGH){
          digitalWrite(3, currentPushButton2);
        lastPushButton2 = currentPushButton2;
      case B00000100:
        currentPushButton3 = !currentPushButton3;
        if(lastPushButton3 != currentPushButton3 == HIGH){
          digitalWrite(4, currentPushButton3);
        lastPushButton3 = currentPushButton3;
      case B00001000:
        currentPushButton4 = !currentPushButton4;
        if(lastPushButton4 != currentPushButton4 == HIGH){
          digitalWrite(5, currentPushButton4);
        lastPushButton4 = currentPushButton4;
     }// ------end of switch Statement
//------------------------------------------------end main loop
byte shiftIn(int myDataPin, int myClockPin) {
    int i;
    int DigitalReadDataPin = 0;
    int pinState;
    byte myDataIn = 0;
    for (i=7; i>=0; i--)
      digitalWrite(myClockPin, 0);
      delayMicroseconds(0.2);
      DigitalReadDataPin = digitalRead(myDataPin);
      if (DigitalReadDataPin) { //this means if DigitalReadDataPin == HIGH
        pinState = 1;
        //set the bit to 0 no matter what
        myDataIn = myDataIn | (1 << i);
      else {
        pinState = 0;
      digitalWrite(myClockPin, 1);
    return myDataIn;
