I have been trying to integrate a 4051 mux into my project. With two separate chips, I wired it up how I thought it should be, only to find the Arduino's 5v rail pulled down close to 4.2v and the chip heating up! Fortunately, no damage appears to have been done to the Arduino; I'm not sure I can say the same for the 4051's though. I did some searching for breadboard examples, to see where I might have gone wrong, and I think I've found the problem. The datasheet for the 4051 says:
Pin 7 - Vee - Supply voltage
Pin 8 - Vss - Ground supply voltage
Pin 16 - Vdd - Supply voltage
So, first of all, color me confused that there are two "supply voltage" pins. Some internet searching indicates that Vdd is usually the +5 rail and Vee is usually the negative rail. Ok. The first time I hooked the chip up, I put 5v on both pins 16 and 7, because they're both labeled "supply voltage" so why wouldn't they both get the same input?
Anyway, after further searching, I found a page on garagelab.com that seems to indicate that both Vss and Vee should be ground, which is probably where my problem came up. I haven't tried it again yet... This seems like a horribly misleading way to label and describe the pins. If pin 7 should be ground and pin 16 should be +5 volts supply, why would they both be labeled "supply voltage"?!?!
