40x 4 lcd interface with arduio
Hai,
I am try to interface arduino with 40 x 4 lcd display.
I am using below mentioned code.
/* The circuit:
  • LCD RS pin to digital pin 7
  • LCD Enable pin to digital pin 6
  • LCD Enable2 pin to digital pin 8
  • LCD D4 pin to digital pin 5
  • LCD D5 pin to digital pin 4
  • LCD D6 pin to digital pin 3
  • LCD D7 pin to digital pin 2
  • LCD R/W pin to ground
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(29,26,27,38,39,40,41);
// set up the LCD’s number of columns and rows:
lcd.begin(40, 4);
// Print a message to the LCD.
lcd.print(“hello, world!”);
lcd.begin(40, 4);
i am not getting any message in disaply.
Hi, Two things:
  • do you have the recommended contrast potentiometer connected? Can you se any changes when you adjust it?
  • Remove the two lines inside Loop: You are constantly resetting the LCD with lcd.begin
Let us know...
