433 MHz Radio Frequency Kit
I bought this kit: RADIO KIT
But I didn't found any example to work with it. I heard about some libraries developed to simplify the comunication with these kind of modules.
do you know something about it?
Thank you in advance,
Fabrizio.
Have you looked into Virtualwire? It has worked nicely for me with other 433 MHz units.
Are you talking about this:
http://www.open.com.au/mikem/arduino/VirtualWire.pdf
Thank you...
p.s. I would work in Boston, my dream is the MIT ... You are from Boston.. I like it !!! :)
That’s what I’m talking about.
I work outside of Boston, and go in as little as I can - not really a big city kind of guy.
I was reading the PDF , and I notice that I have to program both the transmitter and the receiver, So I will need one arduino close to the transmitter and one to the receiver ?
Or can I program the transmitter to send , for example , 2 types of messages , on the basis of what I want?
For example, can I build a transmitter that send a message at the pushing of a button, without an Arduino attached to it? Thank you
Yes, you generally need a uC at one end creating the message to send, and a 2nd at the other end to receive the message and do something with it. The transmitter only sends out what it sees on its data input, if that's what you mean by programming. Virtualwire pretty much demands that, as it wraps some bytes around the message being sent to ensure a good message is received. If you had a clock source and a counter and a memory chip and a shift register then I suppose you could Not have the arduino, and instead read the data from 16 (8? 32?) addresses out of the preprogrammed memory and sent them via shift register to be transmitted, that could probably ensure a good transmission every time. Or, buy something like an ATMEGA48A-PU-ND for $2.58 (digikey price), plus a crystal, 22 pf caps, and a couple of Rs & Cs for some more pennies (dipmicro price) and a bit of perfbooard to put it all on and save yourself a lot of aggravation and have a design you could expand with later.
This is another method to consider, don't know if you had found this or not.
http://arduino.cc/forum/index.php?topic=51225
f.schiano: For example, can I build a transmitter that send a message at the pushing of a button, without an Arduino attached to it?
Well, as said you'll need a microcontroller. But there are a lot of cheap 433MHz remote controls for power sockets and similar devices around. Most of them just send a 4Byte value and you can receive and decode that with a Arduino + your receiver. => http://code.google.com/p/rc-switch/
Sui thank you for the answer, if I had uderstood your concept, I think that the whole thing will be something like this:
ARDUINO+RECEIVER RF 433MHz close to the thing that I want to activate if I receive a kind of signal.
TRANSMITTER RF 433MHz, that could be a remote controller like this: In this way I have to understand what is (for example) the message sent by the remote controller when I press button 1, and then I can use the transmitter without wasting another arduino close to it.
Sorry for my bad English, thank you
Fabrizio.
Typically they send a 24 bit value - in other words just a number between 1 and 16777216 depending on which button you've pressed.
You can find a example here: http://code.google.com/p/rc-switch/wiki/HowTo_Receive
The cheap systems (= the power sockets you find in do it your self stores) are allways sending the same value when pressing the same button but security relevant remotes (= car or garage door locking systems) often use a rolling code algorithm and therefore allways send another code on each keypress. Nevertheless if you have a 433Mhz car key you could give it a try with the libary :)
PS: another cheap and simple way to control a Arduino are infrared remotes
=> http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html
Thank you sui.
Can you post, for me, some links for some controllers of these?
p.s. In these days I was trying to let work some infrared sensors, to start understanding if Infrared could be the way to resolve my problem ;D!!!
bye
see my post in the Domotica topic for more rf stuff
Can you link it?
oh, sorry. didn't look into this topic for some days... here you are:
http://www.pollin.de/shop/dt/NjAzOTQ0OTk-/Haustechnik/Installationsmaterial/Schalter_Steckdosen/Ersatz_Fernbedienung.html
http://www.pollin.de/shop/dt/MzMzOTQ0OTk-/Haustechnik/Installationsmaterial/Schalter_Steckdosen/Funk_Steckdosen_Set_2605.html
http://www.conrad.com/2-part-radio-switch-set-433-MHz.htm?websale7=conrad-int&pi=646443
Don't worry, I will check this links as soon as possible. Bye
Thank you for the links that you send to me, I saw the controller and they are interesting even if the website is completely in German and I don't speak it at all.
However I received my radio modules and in these days I'll try to check them!
I will post here for my developments.
Thank you for your support!!!
I found this :
http://www.sparkfun.com/datasheets/RF/KLP_Walkthrough.pdf
Maybe it could be helpful ... I try to check out this and then i will post here!!!
Bye
Be sure to check out VirtualWire as well. http://www.open.com.au/mikem/arduino/VirtualWire.pdf
