Vitaliy86:
I'm in the same case the sensor, but this analysis is not appropriate.
Tell me which direction to go?
The application record from the sensor.
I agree with your surmise in the next post that the data looks like 36 bits but you will need to log several temperature/humidity readings along with the corresponding bit data to give people a chance to decode the meaning of the bits. The make/model of sensor may also help as someone else may have already done the groundwork, potentially saving you a lot of time.
