433 or 315Mhz RX to switch MOSFET via UNO [SOLVED w/ Thanks to PaulS]
Here is the full code if anyone is trying to do what I did at some stage. You will need to replace the Two values (or more, just copy and past new 'else if' statements. the values will be produced by this code as 'Received Other Value' Serial Prints.
As mentioned in the code, this is a Modifed simple receiving code created by the awesome people at:
  http://code.google.com/p/rc-switch/
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
  mySwitch.enableReceive(0);  // Receiver on inerrupt 0 => that is pin #2
  pinMode(4, OUTPUT);  // Location of Mosfet
  pinMode(6, OUTPUT);  // Operation Indicator LED (optional)
  if (mySwitch.available()) {
    unsigned long value = mySwitch.getReceivedValue();
    if (value == 7419184) // This is the value received when button one on TX is pushed
      Serial.print("Mosfet ON - Value = ");  // This and the next three lines are for debug and testing purposes
      Serial.print(mySwitch.getReceivedValue() );
      Serial.print(" /// ");
      Serial.println("");
      digitalWrite(4, HIGH);   // set the Mosfet On
      digitalWrite(6, HIGH);   // set the LED on
      delay(5000);              // wait for 5 seconds
      digitalWrite(4, LOW);   // set the Mosfet Off
      digitalWrite(6, LOW);   // set the LED Off
    else if (value == 7419139) // This is the value received when button two on TX is pushed
      Serial.print("Mosfet OFF - Value = ");  // This and the next two lines are for debug and testing purposes
      Serial.println("");
    else // If neither of the above two values are received it activates this message.
      Serial.print("Received Other Value:"); // This and the next two lines are for debug and testing purposes
      Serial.println("");
    mySwitch.resetAvailable();
