433 Sender module
hi
this code for Send 'Number' with 433Mhz Module
but code noting compile and show this error: invalid conversion from 'char*' to 'long unsigned int' [-fpermissive]
my code:
#include <Keypad.h>
#include <Wire.h>
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
LiquidCrystal_I2C lcd(0x27,16,2);
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {5, 4, 3, 2};
byte colPins[COLS] = {8, 7, 6};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
const byte maxKeys = 10;
char storedKeys[maxKeys];
byte keyIndex = 0;
void setup(){
mySwitch.enableTransmit(10);
mySwitch.setRepeatTransmit(15);
lcd.init();
lcd.backlight();
char key = keypad.getKey();
if(key != NO_KEY)
if (key == '*')
lcd.clear();
mySwitch.send(storedKeys,24);
lcd.print(storedKeys);
else if(key == '#')
keyIndex = 0;
lcd.clear();
lcd.print("Reset success!");
if(keyIndex < maxKeys)
storedKeys[keyIndex++] = key;
storedKeys[keyIndex] = '\0';
It shows more than that. It shows the line number and column number where the problem occurred.
is wrong.
RCSwitch mySwitch;
is right.
If the problem involves the RCSwitch class, post a link to the library.
not working :confused:
attack my library.
RCswitch.zip (15.8 KB)
The library has two methods to send data:
    void send(unsigned long Code, unsigned int length);
    void send(char* Code);
You are trying to pass a character array to the first method. The method that takes a char array doesn't need the length, because it can determine it.
Well وme what to do?
i need this code!
please repair the code
i want Send number!
please help me
mySwitch.send(storedKeys);
but if not use 24 from this code ~> mySwitch.send(storedKeys,24);
not working
this code success: mySwitch.send(storedKeys); but not Send because need '24'
!? :confused:
3ertegh:
not working
!? :confused:
Because as you can see from the function prototype above, mySwitch.send(storedKeys,24); passes an unsigned long type not a char*. PaulS already told you, the function knows the length of the char array by looking at it.
