433Mhz Modul with Virtual Wire | NRF24l01+ with Mirf/NRF24 didn't working
Hello,
i've tried runnig a 433Mhz modul with the VirtualWire library but they didn't communicate.
Then i've tried runnig 2 NRF24l01+ Modules with the NRF24 library and Mirf library and none of both had worked.
Arduinos used: Arduino 2560 and Arduino Nano 328
Has somone an idea how to solve my problem ? The power supply is from USB on my PC , could this the problem ?
I use the simple Hope 433 Mhz tx and rx modules, and I connect the +5 of the transmitter to the PTT pin of the 328 ( to save even more battery power ) and the data to the nominated data pin.
You have to set which pin is which in setup, and the baudrate of the VW link has to be the same each end of course.
Also you cant use pin 9 or 10 for pwm if you are running VirtualWire.
