I am trying to make 4 LEDs that are controlled by a 433mhz transmitter and receiver, using analog joysticks connected to the transmitter. In the serial monitor on the transmitter, the values on the joystick are correct, however, when checking the serial monitor on the receiver, the data transmitted very quickly turns into garbage, after which it remains in this state until the board is reset.
transmitter
#include <RH_ASK.h>
#include <SPI.h>
int JoystickX1 =0 ;
int JoystickX2 =0 ;
String str_J1;
String str_J2;
String str_out;
RH_ASK rf_driver;
rf_driver.init();
pinMode(A1,INPUT);
pinMode(A0,INPUT);
delay(300);
JoystickX1=(analogRead(A0));
JoystickX2=(analogRead(A1));
str_J1 = String(JoystickX1);
str_J2 = String(JoystickX2);
str_out = str_J1 + "," + str_J2;
static char *msg = str_out.c_str();
rf_driver.send((uint8_t *)msg, strlen(msg));
rf_driver.waitPacketSent();
Serial.println("J1: ");
Serial.println(str_J1);
Serial.println("J2: ");
Serial.println(str_J2);
receiver
#include <RH_ASK.h>
#include <SPI.h>
RH_ASK rf_driver;
String str_J1;
String str_J2;
String str_out;
rf_driver.init();
pinMode(10,OUTPUT);
pinMode(9,OUTPUT);
pinMode(8,OUTPUT);
pinMode(7,OUTPUT);
uint8_t buf [8];
uint8_t buflen = sizeof(buf);
if (rf_driver.recv(buf, &buflen))
str_out = String((char*)buf);
Serial.println(str_out);
for(int i=0; i< str_out.length(); i++) {
if (str_out.substring(i, i+1) == ","){
str_J1 = str_out.substring(0, i);
str_J2 = str_out.substring(i+1);
Serial.print(str_J1);
Serial.print(".");
Serial.print(str_J2);
int J1=str_J1.toInt();
int J2=str_J2.toInt();
if (J1<100){
digitalWrite(10,HIGH);
else if(J1 >600){
digitalWrite(9,HIGH);
else{
digitalWrite(10,LOW);
digitalWrite(9 ,LOW);
if (J2<100){
digitalWrite(8,HIGH);
else if(J2 >600){
digitalWrite(7,HIGH);
else{
digitalWrite(8,LOW);
digitalWrite(7,LOW);
