Hello,
i wrote this code to sent numbers via 433mhz. I want them only to be sent when either pin 10 or 11 are on HIGH. And even if disconnect pin 10 and 11, the numbers are still send although the if-function is wrong. It cant be a hardware-problem because everything works with other codes, which i cant use for this projekt.
#include <VirtualWire.h>
#undef int
#undef abs
#undef double
#undef float
#undef round
int data = 10;
int data2 = 11;
pinMode(data, INPUT);
pinMode(data2, INPUT);
pinMode(3, OUTPUT); //VCC for 433mhz
pinMode(2, OUTPUT); //GND for 433mhz
digitalWrite(3, HIGH); //VCC for 433mhz
digitalWrite(2, LOW); //GND for 433mhz
vw_set_ptt_inverted(true); // Required for RF Link module
vw_setup(2000); // Bits per sec
vw_set_tx_pin(4);
if(data, HIGH){
const char *msg = “1”; // this is your message to send
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx(); // Wait for message to finish
delay(200);}
if(data2, HIGH){
const char *msg = “2”; // this is your message to send
delay(200);}
Does anybody know how to fix this?
If you have other SIMPLE codes for 433mhz, to sent numbers, please tell me
