433mhz receiver
Hello,
I want to make a door contact alarm with a amst-606 433mhz transmitter.
This is the code that I received when i open and closed the door sensor (amst-606 KAKU): Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 on, dim level: 14, period: 259us. Addr 18600926 unit 9 off, dim level: 0, period: 258us. Addr 18600926 unit 9 off, dim level: 0, period: 259us. Addr 18600926 unit 9 off, dim level: 0, period: 259us. Addr 18600926 unit 9 off, dim level: 0, period: 259us. Addr 18600926 unit 9 off, dim level: 0, period: 259us. Addr 18600926 unit 9 off, dim level: 0, period: 258us. Addr 18600926 unit 9 off, dim level: 0, period: 259us. Addr 18600926 unit 9 off, dim level: 0, period: 259us. Addr 18600926 unit 9 off, dim level: 0, period: 258us. Addr 18600926 unit 9 off, dim level: 0, period: 259us.
Has anybody an idea how I can translate this code to my arduino with 433mhz receiver?
When the door is open my LED on pin 13 must be ON, and if possible I want to sent some code's to my 433mhz transmitter to turn some lights on.
I try to understand but I am stuck..
I hope somebody can help me..
If you hope for informed help, you have to explain the problem clearly and completely. Please read and follow the instructions in "How to use this forum".
For example, explain how you accomplished the following:
Also, we need to feel that you've researched the answer yourself. Google turned this up at the top of a rather lengthy list:
http://randomnerdtutorials.com/rf-433mhz-transmitter-receiver-module-with-arduino/
