433mhz rf motor control
Hi Guys/Girls,
I'am a total newbie with Arduino's but here is my problem.
I'am trying to read the value of my X and Y axis on my joystick connected to uno1 and send it through RF to control two dc motors connected to uno2
I'am using
virtualWire
1x XY-MK-5V 433Mhz RF Receiver
1x FS1000A/XY-FST RF 433Mhz Transmitter
2x arduino uno boards
I can read the X/Y values fine and even transmit them
but the receiver end cant distinguish between the signal for X or the signal for Y that's incoming and basically writes nearly all incoming values to X.
I would run both motors through transistors and all i need is a signal to connect transistor.
I have pasted the code below, and any help would be much appreciated.
Receiver Code:
#include <VirtualWire.h>
int led1 = 6;
int led2 = 9;
const int receive_pin =  3;
int joyxVal;
int joyyVal;
struct package
 int joyxVal;
 int joyyVal;
typedef struct package Package;
Package data;
 pinMode(led1,OUTPUT);
 pinMode(led2,OUTPUT);
   // Initialise the IO and ISR
   vw_set_rx_pin(receive_pin);
   vw_setup(500);   // Bits per sec
   vw_rx_start();       // Start the receiver PLL running
   uint8_t buf[sizeof(joyxVal)];
   uint8_t buflen = sizeof(joyxVal);
  uint8_t buf2[sizeof(joyyVal)];
  uint8_t buflen2 = sizeof(joyyVal);
if (vw_have_message())  // Is there a packet for us?
   vw_get_message(buf, &buflen);
   memcpy(&joyxVal,&buf,buflen);
   Serial.println("xaxis");
   Serial.println(joyxVal);
   digitalWrite(led1,HIGH);
   digitalWrite(led2,LOW);
   vw_get_message(buf2, &buflen2);
   memcpy(&joyyVal,&buf2,buflen2);
   Serial.println("yaxis");
   Serial.println(joyyVal);
   digitalWrite(led2,HIGH);
   digitalWrite(led1,LOW);
Transmitter Code
//Connected Joystick to analog pins
int joyXaxis = A0;
int joyYaxis = A1;
struct package
int joyxVal ;
int joyyVal ;
Package data;
//begin serial comm
// Sets pin 3 as the TX pin
vw_set_tx_pin(3);
// Required for inverting signal
vw_set_ptt_inverted(true);
// Bits per sec
vw_setup(500);
//read the analog value
int joyxVal = analogRead(joyXaxis);
//map x to digital values
joyxVal = map (joyxVal, 0 , 1023, 0, 255);
int joyyVal = analogRead(joyYaxis);
//map y to digital value
joyyVal = map (joyyVal, 0, 1023, 0, 255);
vw_send((uint8_t *)&joyxVal, sizeof(joyxVal));
vw_wait_tx(); // Wait until the whole message is gone
Serial.println("joystick X axis = ");
Serial.println("data sent from x axis");
Serial.println("**************");
vw_send((uint8_t *)&joyyVal, sizeof(joyyVal));
Serial.println("joystick Y axis = ");
Serial.println("data sent from y axis");
Serial.println("****************");
Please edit your post to add code tags ("</>" button).
I noticed this topic because I'm trying to do something similar.
Try send both the X and the Y values together instead of as separate messages.
In other words, instead of using int joyyVal and int joyyVal use the Package data you already have defined.
so replace vw_send((uint8_t *)&joyxVal, sizeof(joyxVal)); with something like this:
data.joyxVal = joyxVal
data.joyyVal = joyyVal
vw_send((uint8_t *)&data, sizeof(data));
and the corresponding change on the receiver that reads into data and then use it's to values instead of two individual int variables.
Not sure if that code of mine's 100% but the concept is sound
Hey thanks for the reply I will try this out tomorrow and get back you, it looks good thou.
