Hey guys,
I'm hoping to get some help with 433mhz transmitter/receiver devices like this one
I'm trying to decode my garage door remote signal but have run in to some troubles.
I've read through the forums and tried all suggestions including:
- rc-switch library - no success in getting a signal received with the garage door remote
- 433Utils - Limited success in getting the sanity checks working
- VirtualWire library - send and receive sketches working using two Arduinos
- Custom sketch I found on the forums somewhere - This at least picks up something, but the signal received is very inconsistent between button presses
I've also tried a few other things like hooking up the receiver pin to a scope which reveals a ton of noise on the channel. This can also be seen in the following video in which I've used one of the sanity check sketched from 433Utils which basically ties the light on D13 to the state of the 433MHz receiver pin
As you can see by the rapidly blinking light there is a fair bit of noise on the channel.
I'm confident the garage door remote is at the right frequency as my receiver since the D13 led blinks when I press the button, as can be seen in the following video.
I'm stuck at this point and don't know what else to try.
I've got another transmitter/receiver pair in the mail so I'll try this again when it comes in to make sure it's not the device.
Any ideas would be appreciated.
Thanks.
