Hello,
New to arduino have a project to turn on a motor from a relay over a 433MHZ transmitter receiver. I found a sketch to turn it on and after doing the diagram it works but only turns the relay on. I would like to turn it off by the transmit button or have the receiver reset after 3 seconds. any help is greatly appreciated.
Transmitter Sketch:
#include <VirtualWire.h>
int Button1 = 2;
boolean val ;
pinMode(13,OUTPUT);
pinMode (Button1, INPUT);
vw_set_tx_pin(12);
vw_setup(4000);// speed of data transfer in bps, can max out at 10000
char *senddata="0123456789abcdef";
val = digitalRead (Button1);
if (val == 0){
Serial.print(val);
digitalWrite(13,1);
vw_send((uint8_t *)senddata, strlen(senddata));
vw_wait_tx();
digitalWrite(13,0);
Receiver Sketch:
int Buzzer = 6;
int Relay = 2;
// here i set up the tones, you can change them @ void loop.
int tones[] = {261, 277, 293, 311, 329, 349, 369, 392, 415, 440, 466, 493, 523 ,554};
// 1 2 3 4 5 6 7 8 9 10 11 12 13 14
// You can add more tones but i added 14. Just fill in what tone you would like to use, @ void loop you see " tone(Buzzer, tones[12]); " below, digitalWrite(Buzzer, HIGH);
// here you can change the tones by filling in a number between 1 and 14
Serial.begin(9600); //we wanna be able to read what we got
vw_set_rx_pin(12);//connect the receiver data pin to pin 12
vw_setup(4000); // speed of data transfer in bps, maxes out at 10000
pinMode(13, OUTPUT);
pinMode (Buzzer, OUTPUT);
pinMode (Relay, OUTPUT);
vw_rx_start(); // Start the receiver PLL running
for (int i = 0; i < Buzzer; i++) ;
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // if we get a message that we recognize on this buffer...
String out = "";
// we have data coming in, let's aknowledge somehow that we've received it
digitalWrite(13, HIGH);
tone(Buzzer, tones[2]);
delay(100);
digitalWrite(Buzzer, LOW);
digitalWrite(13, LOW);
noTone(Buzzer);
delay(100);
tone(Buzzer, tones[14]);
delay(100);
noTone(Buzzer);
delay(100);
delay(100);
noTone(Buzzer);
delay(100);
delay(100);
noTone(Buzzer);
delay(100);
digitalWrite(Relay, HIGH);
for (int i = 0; i<buflen; i++)
out +=(char)buf*; // fill the string with the data received*
Serial.println(out); // simple enough*
// digitalWrite(13,0); //transmission ended -
