Hello,
please read before responding. There are many projects ive seen online that feature incomplete codes for the 44 key Ir RGB Led remote/controller boxes commonly included with 5050 led 12 v strips. Has anyone found a fully completed code (arduino or otherwise)for the 44 key version that actually has functioning dimming, jump 3/7, fade3/7 flash and auto settings and also work on wifi too? Many projects Ive come across include the Ir hex codes in the sketch but dont actually have them functioning. I am essentially looking for a clone. I opened one of these controllers up and there was actually a small 8 pin Atmel chip inside it.
i'm using normal LED stripe (pins: Positive, R, G, B)
You're assuming that they're all the same?
(may well be true, but who knows?)
may not be exactly the same but almost the same
Maybe that's why you find they don't work - they're using a (slightly) different code set from whatever you have ... ?
Is this to what you are referring ?
