I have glass edger that used to work automatically between 2 edging stone ,i am building a simulation triggers to the machine that will simulate the automatic jobs between the stones.I am new to coding so i want to make sure i did the sketch right,please advise...
i want 3 relays to work in a pattern, relay 1,2 turn on for 2 sec then off (relays on board will be normally open) then after 32 sec i want to turn relay 1,2 on for 2 sec then off after 4 sec i want relay 1,3 to turn on for 2 sec then off after 32 sec i want relay 1,2 to turn on for 2 sec then off
int relay1 = 2;
int relay2 = 3;
int relay3 = 4;
int relay4 = 5;
int wait = 32000;
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
digitalWrite(relay1, HIGH);
digitalWrite(relay2, HIGH);
Serial.print(Rough edging ON);
delay(2000);
digitalWrite(relay1, LOW);
digitalWrite(relay2, LOW);
delay(wait);
Serial.print(Rough edging OFF);
delay(2000);
delay(4000);
digitalWrite(relay3, HIGH);
Serial.print(Bevel edging ON);
delay(2000);
digitalWrite(relay3, LOW);
delay(wait);
Serial.print(Bevel edging OFF);
delay(2000);
Serial.print(Edging complete);
I did a web search on adding a button to the arduino board to excute these commands but i didnt find any, if some one can guide me i would be greatfull ,i will be waiting for A reply thank you
Note: Many relay modules are Active LOW inputs. The relay activates when the input is LOW and deactivate when the input is HIGH.
johnwasser:
Yes i agree with that i will change the inputs to LOW
Can you guide me with the if else ?
I want to add a push button on the uno to activate what i have wrote so that each time i press the button they get excuted
Try this:
const byte relay1 = 2;
const byte relay2 = 3;
const byte relay3 = 4;
const byte relay4 = 5;
const byte pinSS = 6; //choose whatever pin you want; switch to be SPST-NO MOM; must ground pin when closed
unsigned long wait = 32000;
byte
lastSS;
pinMode( pinSS, INPUT_PULLUP );
lastSS = digitalRead( pinSS );
}//setup
byte
currSS;
currSS = digitalRead( pinSS );
if( currSS != lastSS )
lastSS = currSS;
if( currSS == LOW )
DoRelays();
}//if
}//if
void DoRelays( void )
Serial.println( "Rough edging ON " );
delay(2000);
delay(wait);
Serial.println(" Rough edging OFF" );
delay(2000);
delay(4000);
Serial.println( "Bevel edging ON" );
delay(2000);
delay(wait);
Serial.println( "Bevel edging OFF" );
delay(2000);
Serial.println( "Edging complete" );
}//DoRelays
