Hi everybody,
I’m quiet new in Arduino World so that i have a few questions.
I have modified 4 Servos buyed in Germany from conrad with the name RS 2 JR and i have one Arduino 2009 Board.
I removed Pots and put 2 x 2.7KOhm resistor to get my Servos driving.
Result:
Servo Standing:
Servo1 = 65
Servo2 = 65
Servo3 = 66
Servo4 = 64
I actually thought that the Degree where my servos are still had to be somewhere between 80-90 degrees.
My Servos are still with cca 60 Degrees.
Wenn i opened Servos i so that the plastic barier is allowing cca 120 Degrees (i removed this).
Can it be that my servo was made to go 120 Degrees instead 180 and that now i have a middle point at 65 ?
Second Problem i so is that those servos are not spinning with the same speed!
Its allmoust the same speed but not exactly the same.
How can i make them turn exactly the same speed?
Here is my Code I am using:
#include <Servo.h>
#define FRONTLEFTSERVOPIN 3
#define FRONTRIGHTSERVOPIN 11
#define BACKLEFTSERVOPIN 6
#define BACKRIGHTSERVOPIN 9
Servo frontLeftServo;
Servo frontRightServo;
Servo backLeftServo;
Servo backRightServo;
int robotSpeed = 100;
int rightSpeed = 100;
int leftSpeed = 100;
int delayParam = 50;
robotSetup();
goForward();
delay(delayParam * 100);
goStop();
goBackward();
goStop();
goLeft();
goStop();
goRight();
goStop();
void robotSetup(){
setSpeed(robotSpeed);
pinMode(FRONTLEFTSERVOPIN, OUTPUT);
pinMode(FRONTRIGHTSERVOPIN, OUTPUT);
pinMode(BACKLEFTSERVOPIN, OUTPUT);
pinMode(BACKRIGHTSERVOPIN, OUTPUT);
frontLeftServo.attach(FRONTLEFTSERVOPIN);
frontRightServo.attach(FRONTRIGHTSERVOPIN);
backLeftServo.attach(BACKLEFTSERVOPIN);
backRightServo.attach(BACKRIGHTSERVOPIN);
goStop();
void setSpeed(int newSpeed)
setSpeedLeft(newSpeed);
setSpeedRight(newSpeed);
void setSpeedLeft(int newSpeed)
if(newSpeed >= 100)
newSpeed = 100;
if(newSpeed <= 0)
newSpeed = 0;
leftSpeed = newSpeed * 0.65;
void setSpeedRight(int newSpeed)
if(newSpeed >= 100)
newSpeed = 100;
if(newSpeed <= 0)
newSpeed = 0;
rightSpeed = newSpeed * 0.65;
void goForward()
frontLeftServo.write(65 + leftSpeed);
frontRightServo.write(65 - rightSpeed);
backLeftServo.write(67 + leftSpeed);
backRightServo.write(64 - rightSpeed);
void goBackward()
frontLeftServo.write(65 - leftSpeed);
frontRightServo.write(65 + rightSpeed);
backLeftServo.write(66 - leftSpeed);
backRightServo.write(64 + rightSpeed);
void goRight()
backLeftServo.write(66 + leftSpeed);
void goLeft()
void goStop()
frontLeftServo.write(65);
frontRightServo.write(65);
backLeftServo.write(66);
backRightServo.write(64);
