I've a standard 4x4 membrane keypad.
What I want to do is accept key A/B/C/D as option & then accept corresponding 4 digit number. I thought switch-case should work like this -
void loop ()
key = kpd.getKey();
if (key != NO_KEY)
Serial.print(key);
switch(key)
case 'A':
getA();
case 'B':
getB();
case 'C':
getC();
case 'D':
getD();
The code accepts 1st key (A/B/C/D) perfectly. But switch-case doesn't work. The functions to get numbers like getA() isn't called.
I've tried declaring strings to accept numbers & then converting the strings to int in those functions. Not working.
Also tried making 2 instances of keypad. One with only A/B/C/D & another with only numbers (1-0,*,#). Accepting A/B/C/D using one keypad object "kpd1" & accepting number using second keypad object "kpd2" in respective function. This isn't working either.
In loop, serial monitor shows whichever key pressed i.e. one of these - A/B/C/D
But doesn't go to next function from switch-case where digit entry is taken & number is displayed.
Meanwhile I change my code a bit -
char getKpd1() //This function will accept A/B/C/D return the same char value
char key1 = kpd1.getKey();
if (key1 != NO_KEY)
Serial.print(key1);
return(key1);
void getA() //This function will accept 4 digit number A --- similar function can be written for B/C/D
char key2 = kpd2.getKey();
int bar=Num.length();
if (key2 != NO_KEY && bar<4)
Num = Num + key2;
else if (bar>=4) // This will keep 4-digit number
Num={};
numberA = Num.toInt(); //NumberA is globally declared variable
Serial.print(numberA);
char entry = getKpd1();
switch(entry)
case 'A':
getA();
case 'B':
getB();
case 'C':
getC();
I'll try "Receive Error" code in previous sketch & will post reply. Thanks
Num = Num + key2;
Num={};
First, this code does not block until 4 characters are entered.
Second, what the hell is this:
Yes. I want a 4-digit number.
Num={} makes "Num" string empty.
So if someone provides number with >5 digits it'll go to null & need to be entered again.
Num is String object...not an array..
Make Num an array, NOT String Object and use a counter to see how many digits are entered. If the user enters more than 4, clear the array and start over.
Yup. Got it.
I'll accept 4 digits & then add last '\0' myself. Easy to manage that in code.
But the original problem! Will that swith-case condition work (now referring to modified switch-case code..not the one in OP) ??
Accepting digits & saving to string/array is the next part.
When you are inside the switch case, you will need to re-read the chars again and collect four, so you would probably want a while loop that will allow you to stay inside the case and continue to collect the numbers.
So what you want to write is this:
read the keypad and get a letter, this letter will bring you into the corresponding case.
using a while or do while loop, you re-read the keypad and collect the correct amount of numbers, anymore and you can show an error message
after all the numbers have been obtained, you add the null character.
