4x4 Keypad Password + LCD
So I am making a password system. I don't want it to run void loop until the password has been correctly entered. my code seems to read the key presses but it isn't updating the integer "authorized" so I don't know what to do! Please help :wink:
here is my code:
//YWROBOT
//Compatible with the Arduino IDE 1.0
//Library version:1.1
#include <Wire.h>
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6, 7, 8, 9}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
int time;
int passpos = 1;
int digit1 = 1;
int digit2 = 2;
int digit3 = 3;
int digit4 = 4;
int curdig1 = 0;
int curdig2 = 0;
int curdig3 = 0;
int curdig4 = 0;
int authorized = 0;
void authorize()
  lcd.setCursor(6, 1);
  lcd.print("____");
  if (passpos == 1)
    char key = keypad.waitForKey();
    if (digit1 = key)
      curdig1 = key;
      lcd.print("#");
      passpos = 2;
    else {
      lcd.print("#");
      passpos = 2;
  if (passpos == 2)
    if (digit2 = key)
      curdig1 = key;
      lcd.setCursor(7, 1);
      lcd.print("#");
      passpos = 3;
    else {
      lcd.print("#");
      passpos = 3;
  if (passpos == 3)
    if (digit3 = key)
      curdig1 = key;
      lcd.setCursor(8, 1);
      lcd.print("#");
      passpos = 4;
    else {
      lcd.print("#");
      passpos = 4;
  if (passpos == 4)
    if (digit4 = key)
      curdig1 = key;
      lcd.setCursor(9, 1);
      lcd.print("#");
      passpos = 5;
    else if (passpos == 5 && curdig1 == digit1 && curdig2 == digit2 && curdig3 == digit3 && curdig4 == digit4)
      authorized = 1;
      lcd.clear();
      authorize();
  lcd.init();
  lcd.init();
  lcd.backlight();
  lcd.setCursor(4, 0);
  lcd.print("Password:");
  authorize();
  lcd.print(authorized);
  char  key = keypad.getKey();
  if (key) {
    lcd.print(key);
At the very least, you probably want == (test for equality) not = (assignment) in many places.
At a glance, the logic for getting out when passpos becomes 5 don’t look right.
Trace it by hand, that is “play computer” and walk yourself through it to see… it’s doing what you wrote, maybe not what you think.
a7
