4x4 keypad problem
Good morning all,
i'm using the "classic" 4x4 keypad folloing this circuit
The goal of the project is to get 4 numbers from the keypad and store it in an array.
My first code attempt is this.
int thresholds[16]={2,77,144,202,244,290,311,368,394,424,452,477,496,518,538,556};
char keypad[16] ={'1', '2' ,'3','A', '4' ,'5' ,'6' , 'B' , '7' , '8' , '9' , 'C' , '*' , '0' , '#' , 'D'};
char key;
 int value = analogRead(A0);
 for(int i =0; i <16; i++)
  if(abs(value - thresholds[i])< 5)
    key = keypad[i];
    Serial.println(key);
    while(analogRead(A0) < 1000)
      delay(100);
this worked just fine , but how can i store the values to a global array .
    key = keypad[i];
    someArray[someIndex] = key;
Where someArray is the name of your global array and someIndex is the slot in the array you wan to put the current key in.
