4X4 matrix Keypad with I/O Shift Register
I need help.
I have done some research and my little understanding of keypad scanning is that the ShiftIn value of Input Column should return zero (0) when a keypad button is pressed. Mine is only returning 255 (or 11111111) in BIN. All I need is to track the zero value when a key is pressed and then scan the keys matrix to display the pressed key. I will appreciate any help. I have added my code, schematic and a screen shot of result am currently getting.
const int kbdRows = 4;
const int kbdCols = 4;
int LatchIn = 2; //165 pin1
int ClockPin = 3; // 595 pin11 & 165 pin2
int DataIn = 4; //165 pin9
int LatchOut = 5; // 595 pin12
int DataOut = 6; //595 pin14
int led = 7;
int PinState = 0;
char keys[kbdRows][kbdCols] =
	{ '1','2','3','4' },
	{ '5','6','7','8' },
	{ '9','0','A','B' },
	{ 'C','D','E','F' }
byte KeyIsDown()
	int row;
	int col;
  int rowBits;
	int colBits;
	rowBits = 0X10;
	for (row = 0; row < kbdRows; row++)
		digitalWrite(ClockPin, LOW);
digitalWrite(LatchOut, LOW);
		 shiftOut(DataOut, ClockPin, MSBFIRST, rowBits);
	digitalWrite(LatchOut, HIGH);
	delay(5);
		digitalWrite(ClockPin, HIGH);
		digitalWrite(LatchIn, LOW);
		delay(5);
		digitalWrite(LatchIn, HIGH);
		colBits = shiftIn(DataIn, ClockPin, MSBFIRST);
		for (col = 0; col < kbdCols; col++)
			if (colBits==0) // not sure what condition to put here
			byte keypressed = keys[kbdRows][kbdCols]; // I know this is the right stuff to return
	                return colBits;
			colBits = colBits >> 1;
		rowBits = rowBits << 1;
  /* add setup code here */
	digitalWrite(ClockPin, OUTPUT);
	digitalWrite(DataOut, OUTPUT);
	digitalWrite(DataIn, INPUT_PULLUP);
	digitalWrite(LatchOut, OUTPUT);
	digitalWrite(LatchIn, OUTPUT);
	digitalWrite(led, HIGH);
  /* add main program code here */
	byte retColBit = KeyIsDown();
	Serial.print("ColBit: ");
	Serial.println(retColBit,BIN);
	PinState = digitalRead(DataOut);
	Serial.print("DataOut: ");
	Serial.println(PinState,BIN);
4X4-IO-ShiftReg.pdf (31.7 KB)
Ahhhhh unbelievable, I made such a mistake in the setup, and nobody pointed it out. I was calling digitalWrite insteadof pinMode.
Ok , I was able to get the 74hc595 and 74hc165 shift registers to shift byte in and out. I discovered the initial trouble was the shared clock setting . Now I need help for the section that scans the keypad and return the key pressed. i have attached the serial display output, here is my current code:
int led = 7;
byte currentByte, hByte,  incoming = 72;
byte dataOuttest;
byte dataIntest;
int PinState = 0;
	{ 'C','D','E','F' }
byte KeyDown()
	//595 Here
	for (int row  = 0; row <= kbdRows; row++)
		delayMicroseconds(5);
		shiftOut(DataOut, ClockPin, LSBFIRST, incoming);
		delay(10);
		Serial.print("Row: "); // here was to test for Data Shift Out
		Serial.println(row);
		Serial.println("-----------");
		dataOuttest = digitalRead(DataOut);
        Serial.println(dataOuttest);
		delay(600);
	//165 Here
	incoming = shiftIn(DataIn, ClockPin, LSBFIRST);
	for (int col = 0; col <= kbdCols; col++)
		//------------------------------ I dont know what code to put here to enable me scan the keypad.
		//if (!incoming &(1<<col) )
		//	byte keypressd = keys[row] [col];
		//	Serial.print("keypressd: ");
		//	Serial.println(keypressd);
		if(!incoming==0)                    // here was to test for Data Shift In
			dataIntest = digitalRead(DataIn);
		Serial.print("Col: ");
		Serial.println(col);
		Serial.print("DataIn: ");
		Serial.println(dataIntest);
		Serial.print("InComing: ");
		Serial.println(incoming);
		delay(600);
	} // row end
	pinMode(ClockPin, OUTPUT);
	pinMode(DataOut, OUTPUT);
	pinMode(DataIn, INPUT);
	pinMode(LatchOut, OUTPUT);
	pinMode(LatchIn, OUTPUT);
  KeyDown();
