I have built a 4x4x4 led cube that uses every pin on the Arduino Uno and need a little help and insight as to how to make it easier to program. In the program below you can see that the current system takes a number into either the LED_ON or LED_OFF program and then translates that into the two pins that would need to be on in order to power that specific led, the layers are 1-16 17-32 33-48 and 39-64. This works great except that for large graphics there are a ton of LED_ON(1) LED_ON(2)... for each row then a delay and the same for LED_OFF and that can get kind of very annoying when you just want to test the graphic. To combat this I was trying to come up with a way to load up an array with the LEDs that you would want on and then just cycle through those for each level so there is only 1 LED_ON and 1 LED_OFF for each level. I thought that this would work the way i have it set up but as of right now only LED 1 comes on and stays on and there is no movement of anything else from there on out. Please if anyone knows of a better way to throw large groups of numbers into a system like this or has a different style that I could use, i went for the ultra simplistic way, Let me know and modify the code as you see fit. If you have any questions about my logic or what I would like to see happen feel free to reply or message me.
TLDR: trying to use arrays as a program input and it is not working the program in question is all() all the way at the bottom of my code
Thanks,
for (int i=0; i<20; i++)
pinMode(i, OUTPUT);
all(100);
void LED_ON( int LED)
int level;
int pin;
//Levels
if (LED>=0 && LED<=16) {level=16;}
else if (LED>16 && LED<=32) {level=17;}
else if (LED>32 && LED<=48) {level=18;}
else if (LED>48 && LED<=64) {level=19;}
//LED on each level
if (LED==1 || LED%16==1){pin=0;}
else if (LED==2 || LED%16==2) {pin=1;}
else if (LED==3 || LED%16==3) {pin=2;}
else if (LED==4 || LED%16==4) {pin=3;}
else if (LED==5 || LED%16==5) {pin=4;}
else if (LED==6 || LED%16==6) {pin=5;}
else if (LED==7 || LED%16==7) {pin=6;}
else if (LED==8 || LED%16==8) {pin=7;}
else if (LED==9 || LED%16==9) {pin=8;}
else if (LED==10 || LED%16==10) {pin=9;}
else if (LED==11 || LED%16==11) {pin=10;}
else if (LED==12 || LED%16==12) {pin=11;}
else if (LED==13 || LED%16==13) {pin=13;} //Mixed up wiring these two
else if (LED==14 || LED%16==14) {pin=12;} //Mixed up wiring these two
else if (LED==15 || LED%16==15) {pin=14;}
else if (LED==16 || LED%16==0) {pin=15;}
digitalWrite(pin, HIGH);
digitalWrite(level, HIGH);
void LED_OFF( int LED)
int level;
int pin;
//Levels
//LED on each level
digitalWrite(pin, LOW);
digitalWrite(level, LOW);
void all(int r)
//create array
int led[64];
int i=0;
for(i=0; i<64; i++)
int j=1;
led[i]=j;
j++;
for(i=0; i<r; i++)
for(i=0; i<16; i++){LED_ON(led[i]);}
delay(2);
for(i=0; i<16; i++){LED_OFF(led[i]);}
delay(1);
for(i=16; i<32; i++){LED_ON(led[i]);}
delay(2);
for(i=16; i<32; i++){LED_OFF(led[i]);}
delay(1);
for(i=32; i<48; i++){LED_ON(led[i]);}
delay(2);
for(i=32; i<48; i++){LED_OFF(led[i]);}
delay(1);
for(i=48; i<64; i++){LED_ON(led[i]);}
delay(2);
for(i=48; i<64; i++){LED_OFF(led[i]);}
delay(1);
Shell_4x4x4.ino (15.8 KB)
