4x4x4 LED cube Snake
Hey! I have a problem with my code. The snake starts at 2 leds long, but for some reason the snake doesn't move and there's a gap in the snake... any idea why? I can't find anything
Thanks in advance!
All variables:
//Global Variables(I have more parts that uses these)
int pins[16] = {22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37};
int pins2[4][4] = {{22, 23, 24, 25}, {26, 27, 28, 29}, {30, 31, 32, 33}, {34, 35, 36, 37}};
int lvls[4] = {38, 39, 40, 41};
//All snake variables
int heads[8][3] = {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}};
int length = 2;
int nextLevel = 3;
int pin = NULL;
int currentX = NULL;
int currentY = NULL;
int currentZ = NULL;
int targetX = NULL;
int targetY = NULL;
int targetZ = NULL;
int foodX = NULL;
int foodY = NULL;
int foodZ = NULL;
int bufferX = NULL;
int bufferY = NULL;
int bufferZ = NULL;
int headBuffer = NULL;
boolean trueX = false;
boolean trueY = false;
boolean trueZ = false;
boolean currentTrueX = false;
boolean currentTrueY = false;
boolean currentTrueZ = false;
boolean currentAllTrue = false;
boolean food = false;
boolean ateFoodBool = false;
boolean target = false;
The main code:
void snake()
  if (!food)
    Serial.println("food");
    foodX, foodY, foodZ = spawnFood(NULL, NULL, NULL);
  if (!target)
    Serial.println("target");
    targetX, targetY, targetZ = setTargetPos(targetX, targetY, targetZ);
  Serial.println("display");
  display1();
  Serial.println("pathFineOneMove");
  currentX, currentY, currentZ = pathFindOneMove(currentX, currentY, currentZ, targetX, targetY, targetZ);
  Serial.println("moveSnake");
  moveSnake(NULL, NULL);
  Serial.println("ateFood");
  ateFoodBool = ateFood(ateFoodBool);
  if (ateFoodBool)
    Serial.println("addHead");
    length, nextLevel = addHead(length, nextLevel);
    food = false;
    ateFoodBool = true;
int pathFindOneMove(int currentX, int currentY, int currentZ, int targetX, int targetY, int targetZ)
  if (currentX < targetX)
    currentX++;
    if (currentX != targetX)
      currentX--;
      currentTrueX = true;
  if (currentY < targetY)
    currentY++;
    if (currentY != targetY)
      currentY--;
      currentTrueY = true;
  if (currentZ < targetZ)
    currentY++;
    if (currentZ < currentZ)
      currentY--;
      currentTrueZ = true;
  if (currentTrueX = true)
    if (currentTrueY = true)
      if (currentTrueZ = true)
        currentAllTrue = true;
  return currentX, currentY, currentZ;
void display1()
  for (int y = 0; y < 25; y++)
    //-------------------Display Snake
    for (int h = 0; h < length; h++)
      digitalWrite(lvls[heads[h][1]], HIGH);
      digitalWrite(pins2[heads[h][0]][heads[h][2]], HIGH);
      delay(1);
      digitalWrite(pins2[heads[h][0]][heads[h][2]], LOW);
      digitalWrite(lvls[heads[h][1]], LOW);
    //-------------------Display Food
    digitalWrite(lvls[foodY], HIGH);
    digitalWrite(pins2[foodX][foodZ], HIGH);
    delay(1);
    digitalWrite(pins2[foodX][foodZ], LOW);
    digitalWrite(lvls[foodY], LOW);
int coordToLed(int x, int z, int pin)
  pin = (x * z)-1;
  return pin;
int spawnFood(int foodX, int foodY, int foodZ)
  foodX = NULL;
  foodY = NULL;
  foodZ = NULL;
  foodX = random(1,5);
  foodY = random(1,5);
  foodZ = random(1,5);
  foodX--;
  foodY--;
  foodZ--;
  food = true;
  return foodX, foodY, foodZ;
int setTargetPos(int targetX, int targetY, int targetZ)
  targetX = NULL;
  targetY = NULL;
  targetZ = NULL;
  targetX = random(1,5);
  targetY = random(1,5);
  targetZ = random(1,5);
  targetX--;
  targetY--;
  targetZ--;
  target = true;
  return targetX, targetY, targetZ;
int addHead(int length, int nextlevel)
  int e = nextLevel;
  for (int d = length; d <= 0; d--)
    for (int f = 0; f < 3; f++)
      heads[e][f] = heads[d][f];
    e--;
  for (int g = 0; g < 3; g++)
    if (g = 0)
      heads[0][g] = currentX;
    if (g = 1)
      heads[0][g] = currentY;
    if (g = 2)
      heads[0][g] = currentZ;
  length++;
  nextLevel++;
  return length, nextLevel;
boolean ateFood(boolean ateFoodBool)
  for (int i = 0; i < 3; i++)
    if (heads[0][i] = foodX)
      trueX = true;
    if (heads[0][i] = foodY)
      trueY = true;
    if (heads[0][i] = foodZ)
      trueZ = true;
    if (trueX && trueZ && trueZ)
      return ateFoodBool = false;
  return ateFoodBool;
int moveSnake(int lenght, int nextlevel)
  int e = nextLevel;
    e--;
    if (g = 0)
    if (g = 1)
    if (g = 2)
  for (int g = length+1; g > 7; g++)
    for (int h = 0; h < 3; h++)
      heads[g][h] = NULL;
Running out of memory perhaps ?
Why are the majority of your variables ints when byte would suffice and save space ?
The reason why pretty much all of my variables are ints, is that I have to keep track of what the different things are and where they are in the cube, so I can do that more quickly if it is in int's and not bytes
But it's not memory I have the atmega1280 and I have used 6 736 bytes of a 126 976 byte maximum. So space is no problem
Space may be a problem if you're using too much RAM
Why is it quicker to use ints rather than bytes ? It sounds counter intuitive.
UKHeliBob:
Probably thinks you mean ASCII string representation.
No, the reason I don't do bytes is that I (the programmer, as in the person programming) can see where the different thing are in my cube since I use a 3 coord system (x, y, z).
The cube is only 4 units on each side. If you really wanted to you could fit x, y and z into a single byte, so why the need for individual ints (2 bytes each) for x, y and z ?
Can you explain what this does ?
Are you expecting the pathFindOneMove() function to return 3 values ?
You could fit x, y and z into a single "unsigned int", and still have room for a 4 bit t dimension :wink:
