hi there!
I am working on a project where I have to control individual channel volume using r2s15902fp IC. I have a code for just to control whole volume but not individual channels(left, right, front, woofer). I am attaching the code I have below here. please help me in programming.
#include <Wire.h>
#include <R2S15902FP.h>
#include <Encoder.h>
#include <EEPROM.h>
#include <MsTimer2.h>
#include <boarddefs.h>
#include <IRremote.h>
LiquidCrystal_I2C lcd(0x27,16,2); // Устанавливаем дисплей
IRrecv irrecv(12); // указываем вывод модуля IR приемника
Encoder myEnc(9, 8);// DT, CLK
decode_results ir;
byte a1[8] = {0b00000,0b10101,0b10101,0b10101,0b10101,0b10101,0b10101,0b00000};
byte a2[8] = {0b00000,0b10100,0b10100,0b10100,0b10100,0b10100,0b10100,0b00000};
byte a3[8] = {0b00000,0b10000,0b10000,0b10000,0b10000,0b10000,0b10000,0b00000};
unsigned long time,oldPosition = -999,newPosition;
int menu,vol,vol_d,treb,treb_d,bass,bass_d,in;
byte w,w2,z,z0,z1;
void setup(){ irrecv.enableIRIn(); // запускаем модуль IR
lcd.init();lcd.backlight();// Включаем подсветку дисплея
lcd.setCursor(0,0);lcd.print(" R2S15902FP ");delay(2000);
Serial.begin(9600); lcd.createChar(0,a1);lcd.createChar(1,a2);lcd.createChar(2,a3);
pinMode(DATA, OUTPUT); // D2
pinMode(CLK, OUTPUT); // D3
pinMode(10,INPUT);// МЕНЮ КНОПКА SW энкодера
MsTimer2::set(3, to_Timer);MsTimer2::start(); // АКТИВИРУЕМ ПРЕРЫВАНИЯ ДЛЯ ЭНКОДЕРА
vol = EEPROM.read(0);treb = EEPROM.read(1);bass = EEPROM.read(2);in = EEPROM.read(3);
delay(100);cl();
audio();
void loop(){
if(digitalRead(10)==LOW){menu++;cl();time=millis();w=1;w2=1;if(menu>3){menu=0;}}// меню
if(menu==0){
if (newPosition != oldPosition){oldPosition = newPosition;
vol=vol+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;vol_func();audio();}
lcd.setCursor(0,0);lcd.print("VOLUME ");
lcd.print(" ");lcd.print(-vol);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");vol_d=48-vol;
if(w2==1){
for(z=0,z0=0,z1=0;z<=vol_d;z++,z1++){if(z1>2){z1=0;z0++;}
if(z1==1){lcd.setCursor(z0,1);lcd.write((uint8_t)0);lcd.setCursor(z0+1,1);lcd.print(" ");}}
if(z1==3){lcd.setCursor(z0,1);lcd.write((uint8_t)1);}
if(z1==2){lcd.setCursor(z0,1);lcd.write((uint8_t)2);}w2=0;}}
///////////////////////// TREBLE +/-14 dB /////////////////////////////////////////////////////////
if(menu==1){
if (newPosition != oldPosition) {
treb=treb+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;treb_func();audio();}
lcd.setCursor(0,0);lcd.print("TREBLE ");
lcd.print(" ");lcd.print(14-treb2);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");treb_d=28-treb2;
if(w2==1){
for(z=0,z0=0,z1=0;z<=treb_d;z++,z1++){if(z1>2){z1=0;z0++;}
if(z1==1){lcd.setCursor(z0+3,1);lcd.write((uint8_t)0);lcd.setCursor(z0+1+3,1);lcd.print(" ");}}
if(z1==3){lcd.setCursor(z0+3,1);lcd.write((uint8_t)1);}
if(z1==2){lcd.setCursor(z0+3,1);lcd.write((uint8_t)2);}w2=0;}}
///////////////////////// BASS +/-14 dB /////////////////////////////////////////////////////////
if(menu==2){
bass=bass+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;bass_func();audio();}
lcd.setCursor(0,0);lcd.print("BASS ");
lcd.print(" ");lcd.print(14-bass2);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");bass_d=28-bass2;
if(w2==1){
for(z=0,z0=0,z1=0;z<=bass_d;z++,z1++){if(z1>2){z1=0;z0++;}
///////////////////// IN /////////////////////////////////////////////////////////////////////////
if(menu==3){
in=in-newPosition;myEnc.write(0);newPosition=0;time=millis();cl();w=1;w2=1;in_func();audio();}
lcd.setCursor(0,0);lcd.print("INPUT ");lcd.print(in+1);
if(millis()-time>10000 && w==1){
EEPROM.update(0,vol);EEPROM.update(1,treb);EEPROM.update(2,bass);EEPROM.update(3,in);
menu=0;w=0;w2=1;cl();}
void in_func(){if(in>2){in=0;}if(in<0){in=2;}}
void bass_func(){if(bass>14){bass=14;}if(bass<0){bass=0;}}
void treb_func(){if(treb>14){treb=14;}if(treb<0){treb=0;}}
void vol_func(){if(vol<0){vol=0;}if(vol>99){vol=99;}}
void cl(){ir.value=0;delay(300);lcd.clear();}
void to_Timer(){newPosition = myEnc.read()/4;}
void audio(){
Slot1(in,0,0,bass,treb,0);
// input selector 1...3 === int 0...2
//REC-Output Gain Control int 0...6 dB === int 0...3
//ADC Input ATT 0...-6 dB === int 0...3
//bass int 0 === +14dB int 8 === 0dB int 15 === -14dB
//treble int 0 === +14dB int 8 === 0dB int 15 === -14dB
//Input Gain 0...14 dB === int 0...7
Slot2(0,vol,0,vol); // gain0, volume0, gain1, volume1
Slot3(0,vol,0,vol); // gain2, volume2, gain3, volume3
Slot4(0,vol,0,vol); // gain4, volume4, gain5, volume5
// gain 0...14 dB === int 0...7
// volume 0...-99 dB === int 0...100
