button 1,3,5 work fine but 2 and 4 need to have +ive and -ive reversed (compared with the other 3) to have them register high when pressed.
I have used the stateChangeDetection example and expanded that out for all 5 buttons but also running it button by button on the same pin is the same.
The problem is across both 2 uno's and a mega2560.
Is there something obvious I am missing or doing wrong?
Please read the post at the start of any forum , entitled "How to use this Forum".
OR http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What do you have to wire reversed, LED? Button?
Can you post a picture of your project so we can see your layout?
State change detection (edge detection)
Often, you don't need to know the state of a digital input all the time, but
you just need to know when the input changes from one state to another.
For example, you want to know when a button goes from OFF to ON. This is called
state change detection, or edge detection.
This example shows how to detect when a button or button changes from off to on
and on to off.
The circuit:
- pushbutton attached to pin 2 from +5V
- 10 kilohm resistor attached to pin 2 from ground
- LED attached from pin 13 to ground (or use the built-in LED on most
Arduino boards)
created 27 Sep 2005
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/ButtonStateChange
// this constant won't change:
const int s1 = 47; // the pin that the pushbutton is attached to
const int s2 = 48;
const int s3 = 49;
const int s4 = 50;
const int s5 = 51;
const int s6 = 12;
const int ledPin = 13;
int buttonPushCounter = 0; // counter for the number of button presses
int s1s = 0; // current state of the button
int s2s = 0; // current state of the button
int s3s = 0; // current state of the button
int s4s = 0; // current state of the button
int s5s = 0; // current state of the button
int s6s = 0; // current state of the button
int lb1s = 0; // previous state of the button
int lb2s = 0; // previous state of the button
int lb3s = 0; // previous state of the button
int lb4s = 0; // previous state of the button
int lb5s = 0; // previous state of the button
int lb6s = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(s1, INPUT);
pinMode(s2, INPUT);
pinMode(s3, INPUT);
pinMode(s4, INPUT);
pinMode(s5, INPUT);
// pinMode(s6, INPUT_PULLUP);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
// read the pushbutton input pin:
s1s = digitalRead(s1);
s2s = digitalRead(s2);
s3s = digitalRead(s3);
s4s = digitalRead(s4);
s5s = digitalRead(s5);
// s6s = digitalRead(s6);
if (s1s != lb1s) {
if (s1s == HIGH) {
buttonPushCounter++;
Serial.println("1 on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
Serial.println("1 off");
delay(50);
lb1s = s1s;
if (s2s != lb2s) {
if (s2s == HIGH) {
Serial.println("2 on");
Serial.println("2 off");
delay(50);
lb2s = s2s;
if (s3s != lb3s) {
if (s3s == HIGH) {
Serial.println("3 on");
Serial.println("3 off");
delay(50);
lb3s = s3s;
if (s4s != lb4s) {
if (s4s == HIGH) {
Serial.println("4 on");
Serial.println("4 off");
delay(50);
lb4s = s4s;
if (s5s != lb5s) {
if (s5s == HIGH) {
Serial.println("5 on");
Serial.println("5 off");
delay(50);
lb5s = s5s;
if (s6s != lb6s) {
if (s6s == HIGH) {
Serial.println("6 on");
Serial.println("6 off");
delay(50);
lb6s = s6s;
// turns on the LED every four button pushes by checking the modulo of the
// button push counter. the modulo function gives you the remainder of the
// division of two numbers:
if (buttonPushCounter % 4 == 0) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
The other code that the above is based off is this
and on to off.
The circuit:
Arduino boards)
created 27 Sep 2005
by Tom Igoe
const int buttonPin = 7
const int ledPin = 13; // the pin that the LED is attached to
// Variables will change:
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
pinMode(buttonPin, INPUT);
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button went from off to on:
Serial.println("on");
// if the current state is LOW then the button went from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state, for next time through the loop
lastButtonState = buttonState;
To get button number 2 and 4 to go HIGH when pressed I have to reverse the polarity on the power to those batteries. IE change them from +5v to the button to be GND to the button.
Once that is done when the button is pressed it goes HIGH.
All 5 buttons are exactly the same and in the code taken from the example menu of the software with only one digital pin used I can physically plug in button 1,3,5 and they all work wired from the image in my first post, with button 2,4 they are straight away ON according to serial monitor but they are all wired exactly the same way
imblunt:
I don't understand this..
Are ALL your switches the same?
Can you post a link to data/spec or where you bought the switches please?
Are they ALL wired the same.
Have you swapped your switches around the so you can see if it is a switch problem or wiring?
Do you have a DMM to measure circuit voltages.
I think we need to see a picture of your project so we can, see how you have wired your project.
Thanks.. Tom....
Yes all the switches are the same, removing the switch from the circuit and using a jumper cable has the same symptoms.
I don't have a spec sheet for the switches but they are a generic momentary push button switch available from jaycar.
I have rewired this circuit 3 times with new cabling and pullup resistors to try and eliminate where the problem is.
However every time that I do that the problem is still there.
The buttons are mounted on a board at the top of the frame they then feed to the circuit board on the right of the frame which has a 10K pull up that also has the + from the arduino and the feed to the switch and arduino D pin.
Note there are a number of other things in this photo that are also in the process of being cabled up hence the rats nest at this point.
Your Fritzy shows PULL DOWN resistors!!!!
Please post the code you are using?
What pins are the buttons connected too?
Tom...
TomGeorge:
Your correct it is a pull down and not pull up. Its been a long day. also in message 2 change the work batteries for buttons.
The code is available in message 2. currently it is connected as per the code in the first block in message 2.
However if I connect them to other pins the same behaviour exists.
Just have the buttons connected and run this code.
Open the Serial Monitor in the IDE, select 9600 baud.
Note what is displayed when;
NO button is pressed;
Then when a button in turn is pressed, keep the button pressed for at least a second so the display will update.
Agreed with #11. That's the way to wire buttons, and unless using long wires you shouldn't need external resistors at all. Makes life just that little bit easier
Note that a button will record LOW when pressed in that case, HIGH when unpressed.
