5 channel temperature controlled fan controller
Hi I’m new to the forums and I would apreciate some help with my project. I’ve looked all over for help. I’ve built a 5 fan temperature controlled fan controller for my computer. The issue that I’m having is with the LM35dz temperature sensor. The sensor was giving me huge temperature variations of up to 9 degrees. I have fed the sensor readings through an array to get an average of it to see if I can smoothen it up. it still spikes but not as much (±3 degrees). I forgot to mention that I did add a 47uf capacitor on the analog in. I can’t figure out if the problem is the sensor or my code.
// 5 channel temperature controlled fan controller version 4.7
// David Ramirez
// 12/30/2015
// input sensors.
// assigns the pins for the temperature sensors.
short analog1 = 4,
      analog2 = 5,
      analog3 = 6,
      analog4 = 2,
      analog5 = 3;
// input values.
short avgReading1 = 0,
      avgReading2 = 0,
      avgReading3 = 0,
      avgReading4 = 0,
      avgReading5 = 0;
// assigned fans.
// Assigned the pwm pins from the Uno/Pro Mini.
short fan1 = 10,
      fan2 = 9,
      fan3 = 6,
      fan4 = 5,
      fan5 = 3;
// fan speed.
float fanspeed1 = 0,
      fanspeed2 = 0,
      fanspeed3 = 0,
      fanspeed4 = 0,
      fanspeed5 = 0;
// timed interupts to run multiple fans.
// milliseconds in time.
unsigned short cpuTime = 900,
               ambientTime = 1000,
               hdbayTemp = 1200,
               auxTemp1 = 1300,
               auxTemp2 = 1400;
// time storage.
// stores last time fan was updated.
long previous1 = 0,
     previous2 = 0,
     previous3 = 0,
     previous4 = 0,
     previous5 = 0;
//Containers for temperature control.
float millivolts1 = 0,
      millivolts2 = 0,
      millivolts3 = 0,
      millivolts4 = 0,
      millivolts5 = 0,
      celsius1 = 0,
      celsius2 = 0,
      celsius3 = 0,
      celsius4 = 0,
      celsius5 = 0;
  //analogReference(INTERNAL);
  Serial.begin(9600); // initialize serial communication at 9600 bits per second: for debugging.
  pinMode(fan1, OUTPUT); // Tells the Uno/Pro Mini what kind of pins we are going to use for output. Connect these wires to the base pin of the npn transistor.
  pinMode(fan2, OUTPUT);
  pinMode(fan3, OUTPUT);
  pinMode(fan4, OUTPUT);
  pinMode(fan5, OUTPUT);
  unsigned long currentMillis = millis(); // Returns the number of milliseconds since the Arduino board began running the current program.
  //Fan 1.
  if (currentMillis - previous1 >= cpuTime); {
    float readings1[20];
    for (int i = 0; i < 20; i++) {
      readings1[i] = analogRead(analog1);
      avgReading1 = ((readings1[0] + readings1[1] + readings1[2] + readings1[3] + readings1[4] + readings1[5] + readings1[6] + readings1[7] + readings1[8] + readings1[9] + readings1[10]
      + readings1[11] + readings1[12] + readings1[13] + readings1[14] + readings1[15]+ readings1[16] + readings1[17] + readings1[18] + readings1[19]) / 20);
    millivolts1 = (avgReading1 / 1024.0) * 5000;
    celsius1 = (millivolts1 / 10)+9;
    fanspeed1 = map(celsius1, 0, 184, 0, 255); //charge the 2nd number to adjust the sensitivity. Lower the number the more sensitive to temperature change it becomes.
    analogWrite(fan1, fanspeed1);
  //Fan 2.
  if (currentMillis - previous2 >= ambientTime) {
    float readings2[4];
    for (int i = 0; i < 4; i++) {
      readings2[i] = analogRead(analog2);
      avgReading2 = ((readings2[0] + readings2[1] + readings2[2] + readings2[3]) / 4);
    millivolts2 = (avgReading2 / 1024.0) * 5000;
    celsius2 = (millivolts2 / 10);
    fanspeed2 = map(celsius2, 0, 190, 0, 255);
    analogWrite(fan2, fanspeed2);
  //Fan 3.
  if (currentMillis - previous3 >= hdbayTemp) {
    float readings3[4];
      readings3[i] = analogRead(analog3);
      avgReading3 = ((readings3[0] + readings3[1] + readings3[2] + readings3[3]) / 4);
    millivolts3 = (avgReading3 / 1024.0) * 5000;
    celsius3 = (millivolts3 / 10);
    fanspeed3 = map(celsius3, 0, 190, 0, 255);
    analogWrite(fan3, fanspeed3);
  //Fan 4.
  if (currentMillis - previous4 >= auxTemp1) {
    float readings4[4];
      readings4[i] = analogRead(analog4);
      avgReading4 = ((readings4[0] + readings4[1] + readings4[2] + readings4[3]) / 4);
    millivolts4 = (avgReading4 / 1024.0) * 5000;
    celsius4 = (millivolts4 / 10);
    fanspeed4 = map(celsius4, 0, 190, 0, 255);
    analogWrite(fan4, fanspeed4);
  if (currentMillis - previous5 >= auxTemp2) {
    float readings5[4];
      readings5[i] = analogRead(analog5);
      avgReading5 = ((readings5[0] + readings5[1] + readings5[2] + readings5[3]) / 4);
    millivolts5 = (avgReading5 / 1024.0) * 5000;
    celsius5 = (millivolts5 / 10);
    fanspeed5 = map(celsius5, 0, 190, 0, 255);
    analogWrite(fan5, fanspeed5);
  // for debugging
  Serial.println("fan1");
  Serial.println(celsius1);
  //  Serial.println(avgReading1);
  //  Serial.println("fan2");
  //  Serial.println(avgReading2);
  //  Serial.println("fan3");
  //  Serial.println(avgReading3);
  //  Serial.println("fan4");
  //  Serial.println(avgReading4);
  //  Serial.println("fan5");
  //  Serial.println(avgReading5);
  delay(1500);
/* References: https://www.arduino.cc/en/Reference/Millis
 * http://www.learningaboutelectronics.com/Articles/LM35-temperature-sensor-circuit.php
Three observations,
Firstly, when you declare the readings1 array you do not assign any values to it so they could be garbage in memory.
Secondly, why add each of the values in the array every time you take a reading ? If you must use an array surely you need to take and save all of the readings then sum them.
Thirdly, why use an array at all ? Why not just add each reading to a total as you take it ?
I changed it up a bit. My teacher drill it into our heads not to use an array without properly assigning an amount outside.
//Fan 1.
    int stime1=20;
     int readings1[stime1];
    for (int i = 0; i < stime1; i++) {
      + readings1[11] + readings1[12] + readings1[13] + readings1[14] + readings1[15]+ readings1[16] + readings1[17] + readings1[18] + readings1[19]) / stime1);
I thought it would be easier to just use a for loop with an array to plug in the numbers to spit out what I wanted for me.
It is certainly good practice either to initialise an array to known values before reading any of them but that is not what you are doing.
When you do
you have no idea what values are in the array but then immediately afterwards you use uninitialized values in calculating avgReading1 .
I don't understand why you are doing this inside the for loop that reads the values 20 times. Can you please explain.
Have you written a simple piece of code to check that the temperature sensors are working correctly on their own and as an array using serial monitor?
If I read your sketch, you read analog input 1 then 2 then 3 then 4. after each other.
The arduino only has one AtoD converter.
The AtoD is switched from one input to the next before reading each input.
A problem often arises due to fact that there is a capacitor at the AtoD input.
When the input is switched from one input to the other the capacitor has the charge on it from the previous input.
It takes time for the charge to equal the new switched input, during which the AtoD takes a reading.
This reading not being the correct level of the new switched input, hence you get varying readings.
The solution is to read each input twice and to accept the second reading, the first being taken while stabilization occurs is ignored.
Hope this helps.
Tom… :slight_smile:
:o I almost forgot about this post. Well the update is I now have all of the channels working the way I want them to. I finally came across a good software filter for the sensor readings, which I modified to fit my needs. All fans work indepently from each other with accurate response to counter the temperature change between idle and the computer under different loads. In the next couple of weeks I'm going to be working on implementing PID control and I will be building a new controller board because I don't like the layout of this one and the capacitor values for the fan output are low and hear a lot of whine from the fans at low speeds. I ordered 1000uf 35v caps to replace the 180uf caps to deal with the noise. I was told that 180uf would be enough to filter the noise but it's not. I ended up adding cpu temperature readings to the other two sensors work together with the cpu fan to keep the noise and temperature down which worked nicely in the end. I will include the working code here.
I’m going to post the code in 2 parts.
/* 5 channel temperature controlled fan controller version 1.0
 * David Ramirez
 * 12/30/2015
/* References/credit: https://www.arduino.cc/en/Reference/Millis
 * https://www.youtube.com/watch?v=b3uF3aANszw "electrodacus" from youtube "ADC noise reduction with software filter"
// input sensors.
// assigned pins for the temperature sensors.
short analog1 = 4,
      analog2 = 5,
      analog3 = 6,
      analog4 = 2,
      analog5 = 3;
// Place to store average sensor value.
      avgReading2 = 0,
      avgReading3 = 0,
      avgReading4 = 0,
      avgReading5 = 0;
// assigned fans.
short fan1 = 10,
      fan2 = 9,
      fan3 = 6,
      fan4 = 5,
      fan5 = 3;
//value to get mapped
float fValue1 = 0,
      fValue2 = 0,
      fValue3 = 0,
      fValue4 = 0,
      fValue5 = 0;
// fan speed.
      fanspeed2 = 0,
      fanspeed3 = 0,
      fanspeed4 = 0,
      fanspeed5 = 0;
unsigned short cpuTime = 830,
               ambientTime = 970,
               hdbayTemp = 1070,
               auxTemp1 = 1300,
               auxTemp2 = 1400;
long previous1 = 0,
     previous2 = 0,
     previous3 = 0,
     previous4 = 0,
     previous5 = 0;
//Hold values to calculate temperature.
      millivolts2 = 0,
      millivolts3 = 0,
      millivolts4 = 0,
      millivolts5 = 0,
      celsius1 = 0,
      celsius2 = 0,
      celsius3 = 0,
      celsius4 = 0,
      celsius5 = 0;
second part
/* Warning adjust temps when computer is idle first.
 * Change the 1st number(idle temp)this is slowest you want the fan to be ,and set the second number (max temp)this will be your fans max speed. example:  fanspeed1 = map(fValue,[idle temp],[max temp],0,255)
 * If you want to be somewhat close to your motherboards sensor temperature. Add what ever you need to the end of the celsius equation like this example: celsius1 = (millivolts1 / 10)+5;
  //Fan 1 cpuTime.
  const short stime1 = 40;
                      + readings1[11] + readings1[12] + readings1[13] + readings1[14] + readings1[15] + readings1[16]
                      + readings1[17] + readings1[18] + readings1[19] + readings1[20] + readings1[21] + readings1[22]
                      + readings1[23] + readings1[24] + readings1[25] + readings1[26] + readings1[27] + readings1[28]
                      + readings1[29] + readings1[30] + readings1[31] + readings1[32] + readings1[33] + readings1[34]
                      + readings1[35] + readings1[36] + readings1[37] + readings1[38] + readings1[39]) / stime1);
    if ((readings1[0] + 1 == readings1[1]) || (readings1[0] - 1 ==  readings1[1]) || (readings1[0] + 2 == readings1[1]) || (readings1[0] - 2 ==  readings1[1])); {
      celsius1 = (millivolts1 / 10);
      fValue1 = celsius1;
      fanspeed1 = map(fValue1, 25, 100, 0, 255);
  //Fan 2 ambientTime.
    const short stime2 = 40;
    int readings2[stime2];
    for (int i = 0; i < stime2; i++) {
      readings2[i] = analogRead((analog2+(analog1))/2);
      avgReading2 = ((readings2[0] + readings2[1] + readings2[2] + readings2[3] + readings2[4]
                      + readings2[5] + readings2[6] + readings2[7] + readings2[8] + readings2[9] + readings2[10]
                      + readings2[11] + readings2[12] + readings2[13] + readings2[14] + readings2[15] + readings2[16]
                      + readings2[17] + readings2[18] + readings2[19] + readings2[20] + readings2[21] + readings2[22]
                      + readings2[23] + readings2[24] + readings2[25] + readings2[26] + readings2[27] + readings2[28]
                      + readings2[29] + readings2[30] + readings2[31] + readings2[32] + readings2[33] + readings2[34]
                      + readings2[35] + readings2[36] + readings2[37] + readings2[38] + readings2[39]) / stime2);
    if ((readings2[0] + 1 == readings2[1]) || (readings2[0] - 1 ==  readings2[1]) || (readings2[0] + 2 == readings2[1]) || (readings2[0] - 2 ==  readings2[1])); {
      fValue2 = celsius2;
      fanspeed2 = map(fValue2, 25, 100, 0, 255); //(35.13, 69, 0, 255)
  //Fan 3 hdbayTemp.
    const short stime3 = 40;
    int readings3[stime3];
    for (int i = 0; i < stime3; i++) {
      readings3[i] = analogRead((analog3+(analog1+4))/2);
      avgReading3 = ((readings3[0] + readings3[1] + readings3[2] + readings3[3] + readings3[4]
                      + readings3[5] + readings3[6] + readings3[7] + readings3[8] + readings3[9] + readings3[10]
                      + readings3[11] + readings3[12] + readings3[13] + readings3[14] + readings3[15] + readings3[16]
                      + readings3[17] + readings3[18] + readings3[19] + readings3[20] + readings3[21] + readings3[22]
                      + readings3[23] + readings3[24] + readings3[25] + readings3[26] + readings3[27] + readings3[28]
                      + readings3[29] + readings3[30] + readings3[31] + readings3[32] + readings3[33] + readings3[34]
                      + readings3[35] + readings3[36] + readings3[37] + readings3[38] + readings3[39]) / stime3);
    if ((readings3[0] + 1 == readings3[1]) || (readings3[0] - 1 ==  readings3[1]) || (readings3[0] + 2 == readings3[1]) || (readings3[0] - 2 ==  readings3[1])); {
      fValue3 = celsius3;
      fanspeed3 = map(fValue3, 25, 100, 0, 255);// it was (29.75, 48, 0, 255)
  //Fan 4 auxTemp1.
    const short stime4 = 40;
    int readings4[stime4];
    for (int i = 0; i < stime4; i++) {
      avgReading4 = ((readings4[0] + readings4[1] + readings4[2] + readings4[3] + readings4[4]
                      + readings4[5] + readings4[6] + readings4[7] + readings4[8] + readings4[9] + readings4[10]
                      + readings4[11] + readings4[12] + readings4[13] + readings4[14] + readings4[15] + readings4[16]
                      + readings4[17] + readings4[18] + readings4[19] + readings4[20] + readings4[21] + readings4[22]
                      + readings4[23] + readings4[24] + readings4[25] + readings4[26] + readings4[27] + readings4[28]
                      + readings4[29] + readings4[30] + readings4[31] + readings4[32] + readings4[33] + readings4[34]
                      + readings4[35] + readings4[36] + readings4[37] + readings4[38] + readings4[39]) / stime4);
    if ((readings4[0] + 1 == readings4[1]) || (readings4[0] - 1 ==  readings4[1]) || (readings4[0] + 2 == readings4[1]) || (readings4[0] - 2 ==  readings4[1])); {
      celsius4 = (millivolts4 / 10) + 3;
      fValue4 = celsius4;
      fanspeed4 = map(fValue4, 0, 0, 0, 255); //Currently set to off defualt (fValue5, 28, 80, 0, 255). change the 2nd number to adjust the sensitivity. Lower the number the more sensitive to temperature change it becomes.
//Fan 5 auxTemp2.
    const short stime5 = 40;
    int readings5[stime5];
    for (int i = 0; i < stime5; i++) {
      avgReading5 = ((readings5[0] + readings5[1] + readings5[2] + readings5[3] + readings5[4]
                      + readings5[5] + readings5[6] + readings5[7] + readings5[8] + readings5[9] + readings5[10]
                      + readings5[11] + readings5[12] + readings5[13] + readings5[14] + readings5[15] + readings5[16]
                      + readings5[17] + readings5[18] + readings5[19] + readings5[20] + readings5[21] + readings5[22]
                      + readings5[23] + readings5[24] + readings5[25] + readings5[26] + readings5[27] + readings5[28]
                      + readings5[29] + readings5[30] + readings5[31] + readings5[32] + readings5[33] + readings5[34]
                      + readings5[35] + readings5[36] + readings5[37] + readings5[38] + readings5[39]) / stime5);
    if ((readings5[0] + 1 == readings5[1]) || (readings5[0] - 1 ==  readings5[1]) || (readings5[0] + 2 == readings5[1]) || (readings5[0] - 2 ==  readings5[1])); {
      celsius5 = (millivolts5 / 10) + 3;
      fValue5 = celsius5;
      fanspeed5 = map(fValue5, 0, 0, 0, 255); //Currently set to off defualt is (fValue5, 28, 80, 0, 255).
  /* for debugging
   * comment the ones you don't need with "//"
   * uncomment the ones you want.
//  Serial.println("fan1");
//  Serial.println(celsius1);
//  Serial.println(celsius2);
//  Serial.println(celsius3);
