Hello everyone.
I recently got hold of 3 paper tape punch/readers from the mid 1980s. They are Siemens T1560 models and use 5 hole paper tape punching and reading the Baudot code. I have got 2 of the machines working so far and can use a couple of the serial terminals out there (I am using a windows machine with the punch/reader connected to a Serial to USB converter) including Heavy Metal and RTTYArt. The machines punch and read on 300 baud 7N1 and its all baudot code.
Would anyone be able to help me work out how I could get the machines talking to Arduino?
I have tried connecting the serial connections to an Arduino UNO setting the serial port to 300 Baud 7N1 and I have a piece of tape with the alphabet and numbers punched onto it but all the Arduino serial port spews out is odd non standard letters and symbols.
I'd like to know if anyone else has managed to do this and if so, how.
Any help appreciated.
Thanks,
Steve.S (London UK)
Hi guys. Yep. Its definitely RS232. I had to do some repairs on them so I had to open them up. Firstly replace a burned out tantalum cap and an inductor, secondly I had to reverse engineer the Rs232 socket as the connectors are old military style Plessey connectors. The main PCB contains some microcontroller chips, some EPROMS, RAM and an INS8250 UART chip. You can read about it on the vintage computer forum: http://www.vcfed.org/forum/showthread.php?51306-Paper-tape-readers-x-2-PLease-help
Remington and Sparx you're right. Its RS232 +/- 12V levels so I'm lucky I didn't blow up my Arduino!! Thanks!
However, I've got it punching and reading BAUDOT code using an old windows terminal called RTTYART. Heavy metal works too. I can punch and read using Realterm but Realterm doesn't have a BAUDOT code setting so it punches ASCII code (or the first five bits of it as the puncher and reader are set for 5 hole. I think this can be changed though...
