5 min of delay
hi all, i new one with Arduin o, i want to execute the function after a 5min delay. so how to make 5 min delay. thanks like. if(sensor == 0) { while(1) { gps(); delay(2000) getltlg(); delay(1000); tracking(); delay(1000); delay of 5 min; } }
Look at the included example in the IDE called Digital --> Blink Without Delay
what do you think delay(1000); does ?
it provides 1 sec delay
ykn: it provides 1 sec delay
Using delay() is blocking code.
ieee488: Using delay() is blocking code.
of course - but he does not need anything else apparently (although once he tested his sensor there is no way to exit his while)
so if you wanted 5 minutes?
J-M-L: of course - but he does not need anything else apparently
That's what he thinks now. :-) There is always something else. These newbies have grand plans.
ykn:
hi all,
thanks
like.
if(sensor == 0)
while(1)
gps();
delay(2000)
getltlg();
tracking();
delay of 5 min;
Hi ykn,
Welcome…
Please use the code tag when posting codes.
delay ( 1000 ); //<----- This is a second delay…
what if ???
delay ( 1000 * 5UL ); // <---- Would this provide a 5 second worth of delay?
Anyway looking forward… Please limit the use of delay in your code… Thank you
ieee488: That's what he thinks now. :-) There is always something else. These newbies have grand plans.
everyone needs a grand plan !! ;D :grin: :sunglasses:
(you are conceptually right for a solid approach of course)
Ashraf_Zolkopli:
Hi ykn,
Welcome…
what if ???
[ sir i need 5 min delay]
How many milliseconds there are in 5 minutes?
i want to write a code for GPS location that send the Latitude and longitude after each 5 min , when the button is pressed. i am confused how to make 5 min delay. please suggest me
delay(1000*60*5); is it work??
Yes Sir! Or you can do the calculation yourself. 5 minutes is 300 seconds. delay(300000);
If you want something crazy like 24 hours delay, you can use delay(86400000);
Testing that will, of course, take a while ...
ykn:
delay(1000605);
is it work??
almost you need to tell the compiler that this needs to be done using unsigned long numbers or the pre-processor will mess up and do that with integers → add ul after one of the number and then the pre-processor will understand this needs to be done using unsigned long format
delay(1000[color=red]ul[/color]*60*5);
ykn: i want to write a code for GPS location that send the Latitude and longitude after each 5 min , when the button is pressed.
makes for a long button press...
thanks for your valuable response
as mentioned above the way your code is today, once you press the button you never exit your while(1) loop - is that really what you want?
