In the following code I run a GPS for 5 minutes to ensure that it downloads the ephimeris data.
This code only runs once.
For some reason, my millis timer is not stopping
unsigned long gpsOnTime;
unsigned long gpsRunInterval = 1000UL * 60 * 5; // 5 minute interval
boolean gpsDownloadInitial = false;
if (gpsDownloadInitial == false)
gpsDownloadInitial = true;
downloadGPS();
void downloadGPS() {
gpsOnTime = millis();
Serial.println("Start GPS Download");
if (gpsOnTime > 0) // The GPS is Downloading
if (millis() - gpsOnTime > gpsRunInterval) // It's time to stop GPS downloading
// stop GPS downloading and clear the gpsOnTime time
Serial.println("Stop GPS Download");
gpsOnTime = 0;
Shouldn't you be setting this to the current time otherwise
Will be true immediately
Reread the sketch... It actually guards against that, but is totally bogus in other ways.
Firstly downloadGPS() is correctly guarded by the boolean gpsDownloadInitial, so that it is only
called once (which is much easier to do by calling it in setup() anyway, but whatever)
Secondly downloadGPS() seems to assume that millis() cannot return zero. Incorrect assumption.
Thirdly downloadGPS() exits immediately having done nothing, never to be called again, so the
test for stopping downloading can never happen again.
