I want to make a robot hand for my school proyect using 5 servo motors Savox SC-0252MG Metal Gear Standard Digital Servo (http://www.amain.com/Savox-SC-0252MG-Standard-Digital-Metal-Gear-Servo/p183310) and taking values from a medical electrode (EMG) connected to my arm, with an Arduino UNO (maybe R1) and want to know from you guys wich amplifier is more accurate for my proyect and if you can help me with de code too?
Like i said... im a beginner in this world of arduino and i dont know how start.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;Â // create servo object to control a servo
 //myservoa.writeMicroseconds(1500); //set initial servo position if desired
 myservoa.attach(6); //the pin for the servoa control
 myservob.attach(7); //the pin for the servob control
 myservoc.attach(8); //the pin for the servoc control
 myservod.attach(9); //the pin for the servod control
 Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
 //expect single strings like 700a, or 1500c, or 2000d,
 //or like 30c, or 90a, or 180d,
 //or combined like 30c,180b,70a,120d,
 if (Serial.available()) {
  char c = Serial.read(); //gets one byte from serial buffer
  if (c == ',') {
   if (readString.length() >1) {
    Serial.println(readString); //prints string to serial port out
    int n = readString.toInt(); //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
     Serial.print("writing Microseconds: ");
     Serial.println(n);
     if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
     if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
     if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
     if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
    {Â
     Serial.print("writing Angle: ");
     Serial.println(n);
     if(readString.indexOf('a') >0) myservoa.write(n);
     if(readString.indexOf('b') >0) myservob.write(n);
     if(readString.indexOf('c') >0) myservoc.write(n);
     if(readString.indexOf('d') >0) myservod.write(n);
    readString=""; //clears variable for new input
  }Â
  else { Â
   readString += c; //makes the string readString
I can't advise on the signal amplification side, although I'll hazard a guess that noise will be an issue and you may need to investigate how to filter it out.
On the servos, I'd look at the servo knob example, since the use of the potentiometer will probably serve as a mimic for the analog signal from an amplifier. Get a few pots on different analog pins and you can at least get the servos operating.
The pic below shows how you can hook up a bunch of servos. Don't power them from the Arduino although the tutorial tells you to.
