I recently bought a 128x128 screen and i am trying to develop a way to navigate it using a 5-way tactile switch from sparkfun, it consists of 1 switch for each direction (left, right, up, down and center) with a pull-up resistor on each. This is the code i'm using:
void trackball(int &x, int &y)
while(digitalRead(rightpin) == LOW)
x++; //increases x to move right
//if(x > uoled.x_res) x = uoled.x_res;
while(digitalRead(leftpin) == LOW)
x--; //decrease x to move left
if(x < 0) x = 0;
while(digitalRead(uppin) == LOW)
y++; //increase y to move up
while(digitalRead(downpin) == LOW)
y--; //decrease y to move down
if(y < 0) y = 0;
Now when i try to move the "cursor", it jumps in about 20px increments over the screen. Anybody know what i did wrong?
The sketch polls the switches quickly. So, control, slow down, the switch sampling rate. If the switches are checked a lot in a given time there's more movement than there is if the switches are checked much less often over the same period.
replace 500 for time delay you want between recognizing pushes
One of many possible approaches
Dont forget: unsigned long lastmillis;
You probably want (millis() - lastmillis) since the current time is likely to be greater than some previous time.
The 500 value might be overkill... It will prevent the button from activating more than every half second. 100 might be more reasonable, allowing 10 presses per second.
