Do the 5-meter 5050 & 5630 led strips have resistors, diodes, or are they just SMD LEDs linked on copper strip tape?
I ordered (2) 5-meters of each. I want to stick them to plywood, hang upside down as ceiling lights.
Is it better for me to daisy-chain in series, or seperate in paralell? Should I run higher than 12 volts for the whole 5 meters?
My ceiling tiles are 2' x 4'. I was going to cut in 2' lengths in parallel.
SMD 5050 LED Flex Strip light. Simply put, these LED chips are called SMD 5050 because the dimensions of the chips are 5.0mm x 5.0mm. They have 3 LED diodes in one housing (sometimes called tri-chips), and are a lot brighter than individual 3528 LED chips.
The 5630 (5730) LED is basically a stretched 5050 LED with a much wider viewing angle.
You need to connect them in parallel, using a suited 12v power supply, calculate how much Amps you will need.
They already have resistors. You wire them in parallel. Though, for 5m you could be fine just powering from one end.
Qdeathstar:
That's what I was wondering, if I damage this thing by connecting a 12-amp 12v source. Current limiting already built in, that makes this project EASY for a change.
If your power source is capable of producing more current then your load, put a suitably rated fuse would be a good idea.
Tom..
For a 5m run I would at least power both ends because they need a fair bit of power, especially the 5630, they use 90mA per 3 aka about an amp per meter. Nothing will burn if you don't but you will have a gradient in light output because at the end of 5m the voltage will no be 12V anymore
And you don't connect other voltage driven devices, light you tv, oven, lights etc in series do you
septillion:
What I meant, in series was - to leave the entire 5 meters as it comes. -vs- parallel, would be to cut it into 3 or 4 sections, and wire them as parallel. I have to cut it anyway, to fit since it would look rediculous if I try to bend a part of it 180 degree angle.
