5110 lcd and BME280
Hi I have been trying to make a weather station module with 5110 and BME280(with 4 pins vin,gnd,sda,scl) and I found this code somewhere
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
#include <Adafruit_BME280.h>
#include <Wire.h>
Adafruit_BME280 bme; // I2C
// SDA - A4 (D18)
// SCL - A5 (D19)
Adafruit_PCD8544 lcd = Adafruit_PCD8544(7, 6, 5, 4, 3);
// D7 - Serial clock out (CLK)
// D6 - Serial data out (DIN)
// D5 - Data/Command select (DC)
// D4 - LCD chip select (CE)
// D3 - LCD reset (RST)
 lcd.begin();
 lcd.setContrast(60);
 lcd.clearDisplay();
 Wire.begin();
 bme.begin();
void loop(void) {
 lcd.setTextSize(2);
 lcd.setCursor(8,1);
 lcd.print(bme.readPressure()/133.3);
 lcd.setCursor(8,17);
 lcd.print(bme.readTemperature(),1);
 lcd.setCursor(58,14);
 lcd.print((char)9);
 set_text(69,17,"C",BLACK);
 lcd.setCursor(8,34);
 lcd.print(bme.readHumidity());
 set_text(69,34,"%",BLACK);
 lcd.clearDisplay();
 delay(50000);
void set_text(int x,int y,String text,int color){
 lcd.setTextColor(color);
 lcd.setCursor(x,y);
 lcd.println(text);
 lcd.display();
but the lcd shows no data only 0 C 0 % and 0 mmHg so can you help what me please
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
#include <Wire.h>
// SDA - A4 (D18)
// SCL - A5 (D19)
 lcd.begin();
 lcd.clearDisplay();
 Wire.begin();
 bme.begin();
void loop(void) {
 lcd.setTextSize(2);
 lcd.setCursor(8,1);
 lcd.print((char)9);
 lcd.clearDisplay();
 delay(50000);
 lcd.setCursor(x,y);
 lcd.println(text);
 lcd.display();
Moderator edit:
tags added.
Have you adapted and run the "bme280test" example in the Adafruit_BME280 library and does it report that the sensor is working?
Have you gone through the tutorial?
Read the sensor. Then write the numbers you've got.
DON'T CROSS POST!!!!!!!!!!!!!!!!!!!! http://forum.arduino.cc/index.php?topic=525032 I HAVE REPORTED THIS THREAD TO THE MODERATORS
@dezo, please do not cross-post. Threads merged.
