5110 lcd contrast goes away
Hi there!
I have a 5110 display in a project and if the project is not powered on for a longer time or if I touch the display somehow the contrast goes away: you cant read anything anymore.
If I touch the display a few times and press against the screen the constrast comes back.
Any idea how to solve this problem?
Thanks in advance!
asuryan:
Hi there!
Thanks in advance!
These displays are not well connected to their breakout boards. There are a set of conductors on the bottom side of the display which touch traces on the board and are held there by the pressure of the metal frame. It's a very unreliable way to connect them and they often lose contact. This is one of several reasons I don't use these. It is very frustrating to have everything working and then it suddenly stops. A squeeze is required to get it working again.
Thanks for the info.
So there isnt a permanent solution... just press againt the screen and its fine again. :wink:
Thanks anyway!
For projects that need a low power monochrome LCD, I use either the HX1230 or UC1701/ST7920. Both have better backlights than the 5110 and use less power.
Thanks for the tip!
I also like the SSD1306 0.96 or 1.3 (SH1106) OLED displays.
I maybe switch back to them again then for the next project. :slight_smile:
